Chris NottJMB Retrofits
Results 1 to 14 of 14
    dalespitfire's Avatar
    Quattrophenia
    Oct 2009
    150
    Steering Wheel replacement
    Evening Chaps.
    Odd question this one but stick with me!
    My motor is one of the run out B6's with the full Gmbh badged S-Line kit, but none of the interior trinketry!
    I'm wanting to add the door sill scuff plates ideally but the scrappy down the road from me has a saloon and having an Avant I guess the sills are different.
    He does however have an S-Line badged perforated leather steering wheel which looks quite tidy. Airbag intact and everything for Ł70.
    Question is how easy is it to swap a like for like wheel?
    Cheers Lads
    B6 A4 1.8T Avant Quattro LE 2004 | Silver | 111.5k miles
    Done:
    F/R Ambient Lights|Engine Covers|Replaced Badges|100mm Exhaust Tips|18" RS4 Alloys|Hands Free
    A4 nut's Avatar
    wolverhampton
    352
    Is it the 3 leg with the round boss in the middle steering wheel? if it is then i would buy it anyway for that money its worth Ł325 seperate on e-bay does it have multi functions? then get the mfsw module as well you would be on to a winner does it have cruise and dis as well the list goes on. But to the question its not hard to swap there's plenty of threads on it but disconnect the battery when un plugging the airbag is my tip.
    Quattrophenia
    Oct 2009
    150
    Quote Originally Posted by A4 nut View Post
    Yeah, probably a good idea!
    No its just a 3 spoke wheel with an airbag - but it has the perforated leather and the s-line badge which my 3 spoke sport wheel doesn't.
    They seem to go for Ł80-125 on ebay so it on the money.
    I need to have another look at the stalks but dont recall it having cruise.
    Done:
    2,165
    Is the one being scrapped a B6? if not and it's a B7 then you will have the single to dual stage conversion & all the questions... like will the airbag fire in a crash.
    If it's a B6 then it's just a case of removing your old one and fitting the new one, but remember to disconnect the battery.
    Quattrophenia
    Oct 2009
    150
    Quote Originally Posted by B5NUT View Post
    Nah, its a B6 so no two stage firing probs.
    Presume you just disconnect battery, unscrew the airbag from rear, pull airbag away and unclip it, undo wheel boss nut, remove wheel, refit new wheel, refit nut, clip airbag in, rescrew, reconnect battery?
    Done:
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    Get some advice or preferably, get it fitted professionally - some home retro-fit jobs have been invovled in accidents and the airbag hasn't fired!
    That said: best upgrade in my car by a LONG way, especially if it's got the controls!
    LostBok/BahnStormer77
    Quattrophenia
    Oct 2009
    150
    This is not a retro fit of a B7 wheel or a MFSW.
    Its effectively just a straight swap, or in other words I'm paying for a badge and some dimpled cow.
    Done:
    mattyboyc's Avatar
    Sep 2009
    1,224
    Quote Originally Posted by dalespitfire View Post
    Thats it i've changed mine twice as my original had marks in the leather,got a brand new one off ebay for Ł25.00 but it feels thinner than my original.
    So i have been looking at this
    http://cgi.ebay.co.uk/AUDI-A2-A3-A4-...item439d356eb6
    A4 AVANT 1.9TDI 130 SPORT:
    18" RS6'S//TWIN EXHAUST//ALLARD EGR DELETE//AERO WIPERS//B7 KEYS & ENGINE COVERS//BLACK OPTICS //FRONT & REAR S-LINE BUMPERS//TAILGATE SPOILER//S4 HEADLIGHTS,GRILLS & DOOR BLADES//RS4 RARB & PEDALS//FRONT,REAR & FOOTWELL AMBIENT LIGHTING//PUDDLE LIGHTS//FAN JETS//MEDIA SYSTEM//T.V//7" HEADREST MONITORS//REAR BLINDS//REVERSE CAMERA// CRUISE & DIS
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Had my steering wheel off a few times - was investigating alternatives for gear change controls, then found my slip ring needed upgrading for the extra connections required.
    However, when refitting the steering wheel, the manual advises using a new steering wheel nut!
    [Part No. N 907 991 02 @ ~Ł2.57 +VAT]
    (If not have some loctite available to lock the steering wheel nut.)
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    b6 to b6 with no functions is as simple as it gets, straight swap over, NO need to disconnect airbag either, its a myth ! plug and play !
    LOTS DONE, LOTS SPENT !!!!
    2,165
    How do you remove the wheel without disconnecting the airbag wires going to the slip ring?
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    sorry, my bag ! no need to disconnect the BATTERY for airbag / wheel removal.
    2,165
    Have to say I would still disconnect the battery, I've done a few a fair few MFSW & cruise retrofits, and disconnected the battery every time and to date have never had a problem. For the couple of minutes it take to rest the keys/window's, ABS, steering angle etc, for me it's just not worth taking the risk.
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    as above b5nut, done a few now, never had an issue, gareth at hazzy days never disconnects either, which is where i found out there was no reason too.
