Sky InsuranceEM Tuning
Results 1 to 11 of 11
Thread: Alarm help
    Oct 2009
    Kent
    314
    Alarm help
    Good morning everyone,
    I hope you all had a good nights sleep as i was kept awake by an eratic beeping from what seemed like was coming from the speaker in the boot of my a4 1.8t avant, now all my neigbours are out with there pitchforks.
    Any help apart from smashing the **** out of it as it wont be long if it keeps doing it.
    Thanks (1 very pissed off tired and moody a4 owner)
    Xmay4444's Avatar
    On Point!!
    Nov 2008
    LHR
    255
    Apparently it's the alarm battery that needs changing. My previous A4 used to give off three or four beeps periodically at start-up. Sorry I cant help with a solution.
    1.8T quattro S-Line in Akoya Silver, Milltek sports cat & 100mm tipped pipes, black Angel Eyes, 18" RS6's (Vredestein Ultrac Sessanta), Bose Symphony 6CD, Moonroof, Criuse Control, Armrest, Full DIS, 0.5 Leather, F&R PDC, Light Pack, Parrot MKi9200
    Coming soon HID's
    2001 1.8T Sport 0 v Swedish Artic 1
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,704
    It does indeed sound like the batteries in the alarm siren are low. The siren is a sealed unit and quite epxensive (80 is from memory). Or there is a guide from the TTforum HERE which details replacing the internal battery yourself.
    Oct 2009
    Kent
    314
    Thanks guys is there anyway i can get to it to unplug it, as its still going off now.
    Its booked in at volksline tomorrow (thur) but is it worth paying the 60 to have it put through a diagnostic check when i could put the money towards the new siren.
    I'd like to stop it with 4lb of tnt but i like my car
    Mar 2008
    Dorset
    13,704
    Its not something I've ever done to be able to help really. I'm sure you could have a look and if necessary unplug and put it somewhere soundproofed! Worth a try I would think.
    Oct 2009
    Kent
    314
    I think i can see it right underneath the sub-woofer, does anyone know an easy way to get to it?? Or will i have to take the back wheel and plastic wheel arch out to get to it??
    chrisash32's Avatar
    Manchester
    575
    Good topic this... one thing i noted when my car was broken into last week was the alarm is so quiet!
    Is there any way i can configure it in vag-com to give the car horn a blast too?
    Cheers!
    scott b's Avatar
    Warrington, Warrington, United Kingdom
    1,254
    Quote Originally Posted by jolly14 View Post
    youll need to get at it from inside the car.
    remove the boot entry gaurd, 4 torx screws
    remove the philips screw from where the rear cover slides in to,
    remove the rear seat locking bolt (17mm spanner)
    there might be a couple of torx screws in the side panel (the one just below the window line)
    youll now need to remove this trim, its held in with very tight clips that are fixed to the panel, a trim tool will be usefull, theres 2 close to the boot edge, and 1 in the middle of the panel below the window
    that panel should pull out of the way
    now remove the sub unit, 4 bolts/nuts and unclip the wiring loom,
    you should now be able to get to the siren in question.
    Jun 2003
    World of my own
    9,813
    If they're not too corroded then you can just replace the NiCad rechargeable batteries with ones from Maplins. But as said it's getting into the bloody thing without destroying it that's the problem. Also not sure if just disconnecting it will throw up any warnings or effect the immobiliser.
    Alex Turner
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    946
    Here is the complete siren battery replacement and enhancement I did on my own Alarm Siren, which was fitted to my B6 saloon:
    >>Full How To Guide Linked Here<<
    Did this a couple of years ago and had no problems since then.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    Mar 2008
    Dorset
    13,704
    Nice guide mate
