EM TuningChris Nott
Results 1 to 9 of 9
    chrisash32's Avatar
    Manchester
    575
    Who Wants Full DIS and Cruise?
    Spotted this in ebay this afternoon!!!
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220560593782&ssPageNam e=ADME:B:SS:GB:1123#ht_500wt_1182
    Go get it!!!! Its a good price as the SCCM is worth that on its own!
    If anyone needs a lift with fitting, drop me a PM, I might be able to help!
    66
    Mine! Now, just put my mind at rest and tell me these will be fine on a B6???!!!
    66
    When I say fine, I mean I have an avant and full VAGCOM/VCDS, coding details, etc, I mean because they're from a B7.....
    chrisash32's Avatar
    Manchester
    575
    Quote Originally Posted by BigAardvaark View Post
    mine is from a B7 and works fine
    Oct 2009
    29
    Chris, I don't suppose you know how to code this up do you? I have all the stuff except the module but just need someone who knows how to code it on VAGCOM??
    chrisash32's Avatar
    Manchester
    575
    sure do! but you do need a compatible module for cruise.. DIS should work with your standard one.
    Oct 2009
    29
    You have the VAGCOM cable then? I'll pick up a module shortly...
    chrisash32's Avatar
    Manchester
    575
    Quote Originally Posted by slinegaz View Post
    yep, make sure its the correct module.
    Oct 2009
    29
    I believe I need to get a Q module, where abouts in Manchester are you by the way?
