Chris NottVolks Autos
Results 1 to 27 of 27
    London, United Kingdom, United Kingdom
    121
    just changed the coolant temp sensor on 1.9tdi. a quick how to while its still fresh.
    Maybe this is the wrong place to post this so please do move it to where it belongs if needed.
    Ok well i had the dreaded temp sensor issue where the gauge showed running at 50 or 70, never 90. Now i was told i had a faulty waterpump a while ago by a muppet, even though i proved him wrong in the back of my mind i always wanted to resolve issue with the temp sensor.
    What you will need:
    Green temp sensor with new seal and new clip.
    10mm socket
    Flat head screw driver
    G12 and water to top up.
    Thick skin.....
    Right step 1
    Take the dip stick out and then remove the engine cover with a 10 mm socket.
    Step 2
    Unclip bost hose on the upper top left side and pull to one side.
    Step 3
    Locate the temp sensor, on the 1.9 tdi its just under the bost hose on theleft hand side of the engine, it will have 4 wires on a connector on the back of it.
    Step 4
    Remove expansion tank cap.
    Step 5
    Remove the sender connector from the sensor. Not as easy as it sounds, My first attempt to do this was a total failure and it took me nearly 1 month to re attempt. The connector is on pretty tight to say the least, it will come off but the angels you have to work with are not the best so here is how i did it. I turned the sensor so the i can see the clip part of the connector then with a flat head screwdriver put it in the tiny gap on the clip an slowly tuen to relase the connector. It may of just been mine but for some reason the connector would not budge if i was to pressed the clip section on the connecor, hence the use of a screw driver.
    Step 6
    Again with a screwdriver slowly prise out the securing black clip that holds the sensor in the engine.
    Step 7
    With the connector out of the way remove the sensor from the engine. Coolant will flow out, i did not see the point trying to quickly plugging the hole but you can if you want. I just wanted to make sure i got the job done right. Once the coolant is out locate the seal thich should be in the hole on the engine, then remove it.
    Step 8
    Fit the seal to your new green sensor and insert it,fit the new locking clip and attach the connector.
    Step 9
    Top up you coolant with g12 and water if needed(trust me you will need to later) refit everything else. and run the engine while checking for leaks.
    Step 10
    Once you are happy you have no leaks take the car for a little drive to check the sensor works as it should, it took me about 8-9 mins of driving to get the gauge to read 90. Keep an eye on the gauge as mine did dip for a bit then returned to 90.
    Get the car back home and check coolant level again. I had to top up again as i created a small airlock.
    , hense the slight dip in temp on my short run.
    Hey presto Job done. I would say dont rush,stay calm and tripple check everything.
    2002 A4 1.9tdi se 130 saloon in Grey. STANDARD
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    There's another one HERE to accompany yours
    121
    And he has pics too......but the Disclaimer worried me, should i of done one too?
    Oxfordshire
    12
    Having this exact problem! Was going to go and buy a thermostat today, just as well I saw this!
    Looks like that external guide is for 20VT, as its american and they didn't have 1.9TDIs over there, just the 2.7s.
    Going to have a crack at this later, will post pictures if pos.
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,802
    Brilliant guide dude, very clear! I really need to get this done on mine, it rarely sits at 90, and does occassionally fluctuate too.
    I have often wondered if this is why my fuel consumption is so random. Sometimes i get over 50mpg, other times early 40s...and that's with similar driving, temperature outside etc. My thinking was that if the sensor is crapped out, and reading low, the ECU will think the engine is cold, so will be using more fuel to compensate? I may be wrong, but thories are always fun!
    121
    Im not sure the sensor will give better mpg if replaced with a new one, if it does then all well and good. I did my drive to work today and still managed the 56.5 mpg that i usually get.
    Oxfordshire
    12
    Quote Originally Posted by crazy88 View Post
    That would make perfect sense to me! The sensor not only sends info to the temp gauge, but also the ECU. ECU is trying to maintain the perfect AF ratio, so if it thinks the engine is colder than it is, its going to be injecting more fuel. Also on petrol engines, this could cause it to run worse still, as it'll probably be moving the ignition point back in the combustion cycle too?
    Still haven't found my way to Audi just yet...
    121
    Quote Originally Posted by Quackers View Post
    When you put it like that i can see your point.
    Garfie's Avatar
    Jul 2009
    Ipswich, Suffolk
    179
    Mine suffered from mpg down in the low 40's and I changed the maf which made no difference to economy but did to performance. Then I tried the coolant temp sensor which made no difference at all, then eventually changed the thermostat which sorted the economy issue. I now get 100 miles more to a tank of diesel with mpg's up to 48-50mpg.
    chrisash32's Avatar
    Manchester
    575
    Quote Originally Posted by Garfie View Post
    i have changed my CTS as my gauge was all over the place... but now my MPG is awful! I rarely see 30mpg at the moment!! i was seeing 50+ constantly when i first got the car 3 months ago.
    I am tempted to change the thermostat, as it takes AGES to warm up some days... but don't quite fancy doing it myself
    Feb 2012
    London
    91
    can anyone show me the picture of the location of the temp sensor on a 1.9 tdi .. i have changed the wrong one??
    THanks
    Mar 2008
    Dorset
    13,856
    Gstar51's Avatar
    Mar 2012
    Leeds
    79
    Yeah was wondering why mine never gets to 90 deg, ave to get 1 sorted.
    Gstar51's Avatar
    Mar 2012
    Leeds
    79
    Just changed my temp sensor and made no difference to the temp gauge. Any ideas people?
    Oct 2009
    Hull
    1,437
    Thermostat then
    Gstar51's Avatar
    Mar 2012
    Leeds
    79
    Cheers stu!
    Nov 2012
    sunderland
    73
    my car is only doing 38mpg and loosing power every now and then with these codes
    Coolant temp sensor p1256
    Charge pressure control p1557
    so gonna tackle the sencor
    and my temp never goes past 50 :s
    SL11CKK's Avatar
    Apr 2011
    Barking & London
    634
    Quote Originally Posted by stu_m View Post
    Thermostat then
    LOL
    pauldazzle's Avatar
    Cardiff
    621
    Quote Originally Posted by Johnboymason View Post
    P1256 Change the CTS with a genuine VAG part.
    P1557 looks like you have sticking turbo vanes.
    Low temp is probably a stuck open thermostat.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    tbs
    Nov 2012
    44
    Im changing my temp sensor on 2003 1.9 tdi.........see picture below ......can you confirm I can safely remove the big hose arrowed to gain access to the area below that....is that the correct sensor to replace. I took that insert pic by sticking my phone down in the gloom. it looks a really hard spot to get to but i just want to check i've got the right sensor.
    Oct 2009
    Hull
    1,437
    yeah its safe to remove its the air intake you may get a drop of oil in it but dont worry its normal
    and yes thats the sensor
    tbs
    Nov 2012
    44
    Thanks that was a quick reply. Will having the engine warm or cold make a lot of difference to the coolant loss. How much will come out of the sensor hole roughly?
    Oct 2009
    Hull
    1,437
    the only difference it will make is it will heat your hands up lol
    you loose about a litre or so
    Jul 2010
    217
    Well I was going to get my thermostat changed but will give the temp sender a go first.
    Just a heads up, if you manage to pull out the old sensor with o ring and have the new sensor with o ring lined up ready to go in you get minimal fluid loss and have no need to top up. I think I stuck in thumb in inbetween sensors as my oring got stuck.
    I replaced the sensor on my 1.9 A3 last year this way.
    Oct 2012
    426
    When i changed the sensor on my 1.8t i undid the coolant cap and then screwed it back on, lost no coolant at all
    Jul 2010
    217
    Agreed thats what I did, unscrew to let any residue pressure out then replace to complete a suction to slow the flow.
  28. #27
    Nov 2013
    I have the same issue but have replaced my thermostat which seems to help a little but thought I would replace the temp sensor but I purchased the green one from euro car parts but when I have come to look at mine its black? is there any differance? also I only get the sensor not the o ring and the clip as they say they dont do them? Also how do you get in there as there seems no room?
    Its on an 52 reg 1.9 tdi b6 a4
