Chris NottJMB Retrofits
    Electric window problem A4 convertible 53 reg
    In the recent cold weather my car froze up as most did in the mornings. On the cabriolet as you open the door handle it automatically drops the window a centimetre and then puts it back up again once the door is shut. As the window was frozen it could not move so I wiggled it a bit. Ever since then the auto drop and rise has no longer worked.
    Do you think this is a difficult problem to fix or expensive?
    Many thanks
    Apr 2009
    Shirley, Solihull
    542
    he he he its good fun owning a cab in the winter isn't it??!! had to drive holding the door the other day as i managed to get the door open but it wouldn't shut!! anyway...try and reset the window by pressing and holding the switch to the fully open position then pull and hold the switch to the fully closed position. don't let go of the switch either way otherwise it will not reset. fingers crossed, not sure what else it might be?
    Available soon in the For Sale Section.....
    RS4 Pedals - Drivers side mirror mounting/wiring
    B6 Cab Front Grills - Drivers side B6 Cab Headlamp
    Moro Blue Mirror Caps - Full set of Cab Windscreen Surrounds
    Symphony 6 disc Head - Unit Full set of B6 Cab Manuals inc Leather Wallet
    N/S B6 Rear Lamp - RS6 Auto Brake Pedal
    PM for more details.......
    I'll give that a try thanks.
    Yes it is fun in winter! Annoyingly I have a semi empty garage which just needs tidying and I could get it in there. Next year for definite!
    At the moment I have to leave the window slightly down about half a centimetre to allow me to be able to open and shut the door. If I have to use the window at any stage then when I park it takes about 10 attempts to get it to stop at exactly the right level. If it goes too high it doesnt stop until it hits the top and then the safety feature cuts in and lowers it again.
    Thanks for your advice.
    Apr 2009
    Shirley, Solihull
    542
    missed the bit in your first thread about the auto open/close no longer working - definately just needs reseting as i said earlier
    while you're out there get clearing that garage...more cold weather on the way next week brrrrrrr lol
    Just went out and tried it, worked a treat. I had opened it completely and shut it completely recently but guess I can't have done it all at once without stopping half way on the way down or up.
    Thanks for your help, thats made my day, I was thinking something major had gone wrong and needed all sorts of parts replaced!
    Apr 2009
    Shirley, Solihull
    542
    Great stuff, glad its sorted.....its nice to know that not all problems end up bending your wallet
