A4 3.0 Quattro Cabrio Oil leak
mja4cab
North Wales
Hi,can anyone help?
Have had an oil leak for a while now,(not loosing large amounts of oil),and finally had it in the garage today.Called round this evening to check progress and was told that oil is spraying out of the centre of the top right hand pulley,and that Audi were not being helpful regarding a diagnosis or solution.Going to replace the pulley itself as they think that the seal has gone on it ,but then found out you need a special tool to hold things altogether whilst doing the work!
Any ideas?
Mark.
Problem sorted!
It was the plastic seals in the centre of the pullies,two had cracked so replaced all four!
