Chris NottEM Tuning
Results 1 to 8 of 8
    imported_G4JSG
    Boot 12v outlet - anyone got one?
    I bought an ex demo A4 b6 and although it has some nice things and features there isn't a 12v outlet in the boot.
    I bought a flip out one from www.vagparts.com but wanted to know if anyone has a factory fitted unit if they could tell me, or take a picture and show me, where it is fitted so I can make it look standard fit but also use the standard loom wiring which I suspect might be there to connect into??????
    John
    scoTTy's Avatar
    Essex, UK
    1,957
    Re: Boot 12v outlet - anyone got one?
    Whilst talking to some US owners about the boot hooks, one of them took this piccy
    You can see the location of the factory fit power supply.
    I'll be interested if you find a loom already there. The Bose amp is just behind that section so there's definately power there on mine but I'm not sure whether to do this or not.
    imported_G4JSG
    Brilliant. My task for tonight then is to see if the loom is there.
    Watch this space. At least I have the correct part anyway, it looks identical to the one in the picture.
    imported_G4JSG
    [img]/ubbthreads/images/graemlins/frown.gif[/img] [img]/ubbthreads/images/graemlins/frown.gif[/img] [img]/ubbthreads/images/graemlins/frown.gif[/img]
    No loom there for the 12v socket.
    I had a look on the other side and there is more space here, a nice earth point too. I'll run a line from the battery to the boot and put an inline fuse on it.
    Thanks anyway folks
    John
    scoTTy's Avatar
    Essex, UK
    1,957
    Won't it be either upside down or opening towards the seats if you put it on the left?
    imported_G4JSG
    It won't be upside down but will face the seats, my thoughts are it won't be accidentally broken off this way if it does open and something in the boot catches it as you put things in????
    John
    scoTTy's Avatar
    Essex, UK
    1,957
    True...just be careful when you pull things out! [img]/ubbthreads/images/graemlins/wink.gif[/img]
    May 2004
    Netherlands
    My car has the 12V outlet in the boot also, but it is an Avant, 2004 model B6. LEt me know if you need anything in the way of pics and I'll see what I can do. The amp and so on is just rearward of the power port.
