Badger5EM Tuning
Results 1 to 8 of 8
    Dec 2009
    London
    203
    HELP!! Red brake warning light on DIS screen at roundabouts
    Hey all
    i get the red "brake" (symbol/display) on the DIS screen when going around roundabouts.
    i read the maunal and it says check the brake fluids and if its an abs fault, a yellow light will come on.
    in my case, no yellow light comes on, just the red brake symbol on the dis screen, strangely it only beeps a few times whist going round the roundabout then it goes off. i know it cant be brake fluid cos i got it serviced 2 weeks ago.
    could it be a fault on vag com that you just reset? or is this a more serious problem?
    advice pleasee??
    thanks
    2003 Black 3.0 Multironic Cabriolet
    18" RS6s, 6000k HID conversion, Led interior upgrade.
    YE56 NDY reg for sale.
    Jun 2003
    World of my own
    9,813
    Or you could just check the brake fluid level rather than assuming some other type of fault! The fact it was recently serviced means nothing.
    Alex Turner
    howdy quattro's Avatar
    Dec 2007
    boston, lincs
    318
    I'll second that!! check your fluid mate, and your pads all round. If your pads are low then it'd lower your fluid level, so cornering would add to the 'lack' of fluid. happened with mine, put in a new set of rear pads, never had a drama since.
    Apr 2009
    Shirley, Solihull
    542
    Drew...what does the book say.......check your fluid!! If it's low the remaining fluid may move to the side of the reservoir enough to cause the low level warning to function as you go round the roundabout
    Available soon in the For Sale Section.....
    RS4 Pedals - Drivers side mirror mounting/wiring
    B6 Cab Front Grills - Drivers side B6 Cab Headlamp
    Moro Blue Mirror Caps - Full set of Cab Windscreen Surrounds
    Symphony 6 disc Head - Unit Full set of B6 Cab Manuals inc Leather Wallet
    N/S B6 Rear Lamp - RS6 Auto Brake Pedal
    PM for more details.......
    Dec 2009
    London
    203
    LOL, i thought it might be something else as it was too dark last night to check the fluid levels, but i did have a quick look this morning and its sitting just below MIN, so will defo be topping this up.
    can you confirm any dot 4 fluid is okay? and do i just top it up just like that?
    cheers
    Apr 2009
    Shirley, Solihull
    542
    Quote Originally Posted by drewbee View Post
    cheers
    LOL...yes mate, dot 4 and just open the lid and top up to just below max
    Dec 2009
    London
    203
    Quote Originally Posted by markyzs180 View Post
    thanks Marky!! just got the fluid, and poured it in, and i notieced theres some kinda filter in there, and the fluid was just stuck on top of it, gave it a few pokes with a screw driver and it sucked in.
    is the the right method? i did it a few times and got bored, dont fink i poured enough in. LOL
    Apr 2009
    Shirley, Solihull
    542
    you can lift that out! as long as you've got enough in to get over the min mark you should be fine lol
