quattro generation IV
Starting from 1996 on
Audi A4 /
S4 /
RS4 (B5 platform),
Audi A6 /
S6 /
allroad /
RS6,
Audi A8 /
S8 with both manual and automatic transmissions. Also on
VW Passat B5, where it was initially referred to as
syncro, but by the time it reached US soil, it had been re-christened
4motion. Also used on the
Volkswagen Phaeton and
Volkswagen Group D platform sister vehicles; also the
Volkswagen Touareg where they use separate transmissions,
PTUs and front axles.
The manually locking rear differential from the earlier generations was replaced with a conventional open differential, with "Electronic Differential Lock" (EDL) (which detects wheelspin via ABS road wheel speed sensors, and applies brakes to the one spinning wheel, thus transferring torque via open differential to the opposite wheel which has more traction). EDL works at speeds up to 80 km/h (50 mph) on all quattro models (on non-quattro models: up to 40 km/h (25 mph).
System type: Permanent
four-wheel drive.
Torsen T-2 centre differential, 50:50 'default' split, automatically apportioning up to 67% of torque transfer to either front or rear axle.
Open rear differential, Electronic Differential Lock (EDL).
[4]
Open front differential, Electronic Differential Lock (EDL).
[4]
quattro generation V
Starting from 2006 on B7
Audi RS4 and the manual transmission version of the 2007 B7
Audi S4. It was adopted in the entire S4 lineup in 2008.
[1] Will become the standard fitment on all future quattro Audis with longitudinal engine layout.
System type: Permanent asymmetric
four-wheel drive.
Torsen T-3 centre differential, 40:60 'default' split front-rear, automatically apportioning up to 80% of torque transfer to the front axle or up to 100% torque to the rear axle.
[4]
[4]
