Sky InsuranceBadger5
Results 1 to 18 of 18
Thread: HEATED Mirrors
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    HEATED Mirrors
    ive read a few posts about Heated Mirrors and am i correct in thinking all you need to do is relace the mirror glass as the wiring will already be there and bobs your uncle?
    Also whats the trick to removing the mirror covers to check out the wiring
    OEM+
    Grantham, Lincolnshire
    93
    Do you not already have heated mirrors on the car?
    Ebony Black 2004 A4 Avant 1.9 TDi Sport
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,270
    Not that i can tell, were they not part of the winter pack? they dont feel warm when i would expect them to be. As far as i understand (maybe of kilter here) but they should feel warm when the outside temp is below 12 degrees and the rear demister is on and the mirror switch is set to the middle.
    simon.m's Avatar
    Oct 2009
    2,746
    id say have a look in your fuse box see if the fuse is there
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,270
    i thought that they ran from the rear demister, so not requiring a fuse? i will have a look though
    simon.m's Avatar
    Oct 2009
    2,746
    oh maybe didnt think of that haha i no on mine one works and one dont as it must have been smashed at some point
    and the guy before me put a cheapie on it so it dont heat up maaaaaybee the same for yours just maybe thought
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    The trick to remove the mirror glass is to point the mirrors at the ground as far down as they will go, this will enable you to just get a couple of fingers behind the glass. With a gentle but firm pull it will pop free. You will then be able to see how the covers are fixed in place, they are only clips, but a bit fiddly.
    Lots of pics HERE
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,270
    thanks for that, Tricky little devils arnt they. but after looking at that i dont think i need to remove the covers to check the wiring.
    simon.m's Avatar
    Oct 2009
    2,746
    you can see the wiring just by taking the mirror out mate you maybe lucky just putting it to its lowest point and having a look
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,270
    IL GET MY TORCH OUT AND INVESTIGATE
    simon.m's Avatar
    Oct 2009
    2,746
    glass comes out easy mate just put a soft cloth on it to push it back in push softly till you hear a click
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,270
    news update if your interested, I removed the mirror glass last night and the wires are there for the heating element to plug into so i shall get some heated mirror glasses and try - hopefully one of the easiest audi upgrades.
    biyitch's Avatar
    Chocolate? It's doo-doo, baby!
    Southampton
    316
    According to the manual, mine heat when I turn on the rear window demister - I've not touched them when they're supposed to be on to confirm though.
    Audi S4 Avant (B6, 2004) in Goodwood Green.
    Apr 2009
    Shirley, Solihull
    542
    take a look at this thread that was running a couple of weeks ago before you buy any mirrors....always worth doing a search
    http://www.audi-sport.net/vb/showthr...Heated-mirrors
    Available soon in the For Sale Section.....
    RS4 Pedals - Drivers side mirror mounting/wiring
    B6 Cab Front Grills - Drivers side B6 Cab Headlamp
    Moro Blue Mirror Caps - Full set of Cab Windscreen Surrounds
    Symphony 6 disc Head - Unit Full set of B6 Cab Manuals inc Leather Wallet
    N/S B6 Rear Lamp - RS6 Auto Brake Pedal
    PM for more details.......
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,270
    Thanks for that - its probably more tricky than i thought probably wont bother then
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    Quote Originally Posted by Mystik Journeyman View Post
    I've got one that works driver's) and the other one doesn't, so I'm guesssing:
    1) same fuse, so that's not the prob.
    2) el-cheapo glass replacement on the offside, so if I pop that one off, there's gonan be wires that aren't connected?
    LostBok/BahnStormer77
    Apr 2009
    Shirley, Solihull
    542
    Quote Originally Posted by lostbok View Post
    I'd go with the cheapo non heated replacement losty....or has someone retro fitted just one heated mirror before......
    simon.m's Avatar
    Oct 2009
    2,746
    i have the same my drivers one is a cheapy so dont work just the near side one works.
