AH FabricationsJMB Retrofits
Results 1 to 15 of 15
    London, United Kingdom, United Kingdom
    121
    I take it I need a thermostat fitted.
    Ello all, Ive had my A4 now for 4 days now. When i took it for the second testdrive i wanted to makesure the temp went up to 90, as it should. Well it did then went down a bit so i thought it was ok. Well i noticed just now it does not seem to go past 70. Does that mean the stat is stuck on open and will need changing?
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,258
    most probably, mine does the same but a code read says temp guage short to earth on mine, so out will come the dash pod for a closer inspection. what engine is yours?
    121
    Quote Originally Posted by swarcup View Post
    Ahh, yea, that would help. Its za 1.9 tdi 130
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,258
    as far as i know the thermostat is on the back of the engine(windscreen side) so not a massive job you should be able to diy it if your upto it, mines a 2.5v6 so im not to familiar with this engine, but someone with that engine should be along soon to tell you where it is. good luck and all will be well in the audi world soon
    121
    Cheers.
    121
    Sorry guys, any ider what to pay for this. I have a audi garrage across the road from where i work so in theory i could pop it in there but i dont want to pay over the odds to get it done as i know its a simple job to i could just get my mechanic to do it. Choices!!!!
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,258
    part should cost around a tenner tops and a couple of hours labour
    Nov 2005
    Midlands
    215
    I had the same problem with my car - 1.9tdi
    I paid Ł138 at Leicester Audi - covered for 2 years
    - new thermostat
    - new coolant
    - labour (1 hour)
    Lion Garage quoted Ł90 but they were fully booked. Covered for 1 year.
    The thermostat was Ł16 inc the seal plus Ł14 for the coolant. I was going to do it myself but I broke my wrist.
    121
    Well i was expecting Ł100 at my local garrage so paying the extra 38 quid to get it doneby AUDI with original parts and the correct coolant seems to be the way forward i think.
    Garfie's Avatar
    Jul 2009
    Ipswich, Suffolk
    179
    I changed mine the other week (130TDI FWD)
    Parts were about Ł26 from Audi for thermostat, 'o' ring and 1.5 litres of coolant.
    Easy job to do yourself if you have a decent set of allen keys (5mm I think)
    Thermostat is on the right side of engine (passenger side) behind the back of the alternator. Take engine cover off, disconnect battery and remove positive to alternator (gives you more room to work if needed). Then unclip the water pipe from the bottom of the thermostat housing. Undo 2 allen bolts on housing and remove it and thermostat. Replace 'o' ring and thermostat then put the housing back on.
    Refit water pipe and alternator positive wire, reconnect battery, top up with coolant and you're good to go. Let it warm up, topping coolant up as necessary and check for leaks.
    Should take you no longer than half hour.
    Sorted my cool running out and increased my mpg too I also this time of year leave the climate off until the temp reaches 90 as this help it warm up quicker and increases mpg.
    121
    Ahhh, it sounds soo easy!In all fairness i should be able to do it myself, but as i just got the car i dont want to mess about with it too much.
    sammi's Avatar
    verwood, Dorset
    346
    Follow sammi On Twitter
    I think I need to get this done but have a 2.5 TDI V6 Quattro, is it an easy job aswell or a nightmare?
    Nov 2005
    Midlands
    215
    Quote Originally Posted by Garfie View Post
    Straight forward to replace.
    When we replaced the thermostat on my uncles 1.8 t - it took around 2hrs. The alternator, brackets etc had to come off. The thermostat on the 1.8t did look different to the 1.9tdi.
    If I did not break my wrist then I would have replaced it my self and saved myself Ł100 on labour
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,258
    2.5 TDI V6 I CAN CONFIRM IS A NIGHTMARE OF A JOB, BRACE YOURSELF !!
    THE THERMOSTAT IS LOCATED ON THE FRONT OF THE ENGINE (FRONT BUMPER SIDE) BEHIND THE CAMBELT !
    SO IN BRIEF TO CHANGE IT THE FRONT END OF THE CAR IS REMOVED (BUMPER,LIGHTS,COOLANT DRAINED,ALL SORTS OF GIZMOS ARE DISCONNECTED,ALL BELTS REMOVED INCLUDING CAM BELT) ONLY THEN IS IT CHANGEABLE, AND BECAUSE OF THE LABOUR INVOLVED IN ALL THIS IT IS RECOMENDED THAT YOU CHANGE THE WATER PUMP,THERMOSTAT, CAMBELT AND ALL TENSIONERS ETC AT THE SAME TIME.
    I KNOW THIS TO WELL AS MINE IS NEEDING THE SAME ALL IN SHOULD BE LOOKING AT Ł400 -Ł500.
    IF YOUR CAMBELT IS DUE OR NEEDED SOON BETTER TO WAIT TILL THEN
    sammi's Avatar
    verwood, Dorset
    346
    Great!!!
