AH FabricationsSky Insurance
Results 1 to 24 of 24
    biyitch's Avatar
    Chocolate? It's doo-doo, baby!
    Southampton
    300
    Bose Sat Nav System - Rear Speakers not Working
    I've just noticed none of my rear speakers are working (2004 S4 Avant).
    When I messed about with the fader/balance and turned off the fronts, all I could hear was the dash-top speaker (sounded very quiet and tinny - is that normal?) and the sub.
    I'd rather not pull all the trim out from the head unit to the boot looking for the problem so which connections do I need to check?
    Thanks.
    Audi S4 Avant (B6, 2004) in Goodwood Green.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,473
    Quote Originally Posted by Mystik Journeyman View Post
    Sounds like the Bose amp (behind the RHS trim in the boot) isn't getting power or has failed - have you checked all the fuses?
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    biyitch's Avatar
    Southampton
    300
    I have not. Do you know where they are?
    Jun 2003
    World of my own
    9,813
    It can't be a fuse if the fronts are working as they run off the same amp. You'd need to check the rear speaker impedance and ensure they haven't blown. They should read roughly 2 ohms. You can do this at the amp with the HU turned off, rather than tearing the doors apart.
    Alex Turner
    biyitch's Avatar
    Southampton
    300
    Lovely. I'll have a look later on.
    Thanks.
    biyitch's Avatar
    Southampton
    300
    I finally got around to testing the amp connector but it's different to the pin diagram you posted. Do you have any more?
    Mar 2009
    64
    has the unit been retro fitted or is it factory fit?
    have they ever worked to your knowledge?
    It would be the wiring harness is incorrectly set up, I know there is a certain wire for BOSE on the harness that need to be in the correct place.
    On my old S4, I had non BOSE, but when I had Sat Nav retro fitted, the fitter put a BOSE wiring harness on and I had the EXACT same problem as you. He eventually changed the BOSE wire on the harness and it worked.
    Audi S4 Avant 344
    Audi RS 6 Plus 473
    SEAT Exeo TDI 168bhp
    previous:
    Audi RS 4 414 bhp
    Audi RS 6 500 bhp
    Audi S4 Cabriolet V8 344bhp
    Audi S4 344bhp
    Audi RS 6 450bhp
    Audi TT Quattro Sport 265bhp (mapped)
    Audi A4 T Sport 163bhp
    Audi A2 TDi 70mpg
    pjmspeedy's Avatar
    Dude, what's mine say ?
    Apr 2008
    North West
    1,057
    Quote Originally Posted by davidkoulakis View Post
    Time to change your sig David... I see from your posts on RS246 you now have a lovely RS4 B7. Lucky git
    Audi A4 1.8T Sport Cabriolet-Full black leather(Electric & heated),RNS-E,BOSE, OEM Bluetooth,RS4 Mirrors,RS4 FBMFSW,RS4 Pedals,RS4 RARB,Cruise Control,B7 Rear Lights,Ally Inlays,18" RS6 Alloys,HID's/Auto lights with dimming rear view mirror,Coming home lights,Ambient light pack & Rear parking sensors.
    For all your VAG OEM PARTS send me a PM or e-mail me at vagoemparts@ymail.com
    Apr 2009
    Shirley, Solihull
    542
    first thing i would be doing is cleaning up that nice green corrosion on the connector block and, no doubt, the pins on the amp......
    Available soon in the For Sale Section.....
    RS4 Pedals - Drivers side mirror mounting/wiring
    B6 Cab Front Grills - Drivers side B6 Cab Headlamp
    Moro Blue Mirror Caps - Full set of Cab Windscreen Surrounds
    Symphony 6 disc Head - Unit Full set of B6 Cab Manuals inc Leather Wallet
    N/S B6 Rear Lamp - RS6 Auto Brake Pedal
    PM for more details.......
    Jun 2003
    World of my own
    9,813
    That looks the same as the A3 8P Bose connector. I have some of the pinouts:
    Yours looks totally fcuked, should be super clean. Looks like there has been some water damage at some point, could have shorted the output stage.
    I'd check the impedance of the rear speakers and if they are good (showing 1-2ohms) then would think you need a new amp, plenty on ebay.
    The sub works off one of the rear channels and one of the front channels. So when you fade to rear and still get sub, if you balance left & right the sub should stop when full left. this proves the rear signal is getting to the amp, so the problem has to be the amp. Doubt both speakers would blow at the same time.
    Alex Turner
    Jun 2003
    World of my own
    9,813
    Alex Turner
    biyitch's Avatar
    Southampton
    300
    I'll try the fade/balance test. Thanks.
    Is it worth cleaning the corrosion then? If so, what would be safe to use?
    Apr 2009
    Shirley, Solihull
    542
    electrical contact cleaner....
    no_idea's Avatar
    Sep 2008
    Norfolk
    168
    That is the plug for the later style (silver coloured casting with fins on) amp with audio pilot. The plug schematic posted earlier by AndyMac is the black amp without Audio pilot. If you are having problems it just so happens I have got a brand new complete sub enclosure with amp and speaker.(the same as yours) PM if you need any more info.
    A4 3.0 quattro sport avant B6
    May 2007
    Chorley, Lancs
    770
    Hi...all my speakers started crackling and making a bloody awful noise with the ignition off and key removed....root cause was water coming from the flexible rear washer pipe having split between the tailgate of my avant and the car the tailgate hinge. Water had dripped over the amp every time i tried to use the rear washer......
    Cleaned up all the conacts in my Bose Amp connector (which were looking the same as your connector)...worked perfectly after that (thank goodness)
    Looks like water damage has occurred....you may have to get an auto electrician to check out the amp outputs to tye rear speakers ...or you buy a spare amp one off e-bay.
    You must find out how water is dripping onto your bose amp connector.....check the washer pipe from tailgate near the the tailgate hinge...
    (My washer pipe has been fixed now)...
    A4 2.5 Tdi Avant Quattro Sport : 180HP 6 speed, Mauritius Blue, full black leather heated electric front seats, auto lights, Xenons, auto dipping rear view mirror, heated folding door mirrors, cruise control, Bose, full DIS, MFSW, 18" RS6 reps, rear parking sensors, colour coded lower, rear door window blinds, interior & ambient lighting kit, under seat storage, front armrest as standard. RS4 ARB, RNS-e sat nav, Cd Changer, OEM bluetooth fitted by me.
    May 2007
    Chorley, Lancs
    770
    biyitch's Avatar
    Southampton
    300
    UPDATE:
    I cleaned the pins up (easily done on the amp as they were the exposed male type, not sure about the connector end) but it made no difference.
    I'd given up and was gonna open the door panels and test the speakers directly this week but I've just found a couple of pin diagrams for my style amp (32-pin Bose). They're both basically the same apart from a couple of transposed pins (I don't if there's two versions or one's wrong).
    biyitch's Avatar
    Southampton
    300
    I tested the pins and got a good reading so it looks like the amp.
    I'd rather not pay around 100 for a replacement if a component or two can be replaced.
    Does anyone have experience of doing this?
    biyitch's Avatar
    Southampton
    300
    UPDATE:
    I opened up the amp and there was corrosion and damaged pins on some components. Looks like I need a new amp.
    I've had a look on eBay and the model number doesn't match any other's as they have longer codes and start with 8E, 8H or 8P.
    Any ideas?
    Jun 2003
    World of my own
    9,813
    Think you need 8E, just phone up local dealer and ask what the Audi part number should be for your car.
    Alex Turner
    biyitch's Avatar
    Southampton
    300
    Oh, right. Thanks.
    no_idea's Avatar
    Sep 2008
    Norfolk
    168
    If you want I can check the new one I have. It is definitely for a B6 Avant
    no_idea's Avatar
    Sep 2008
    Norfolk
    168
    There should be a part number on the sub enclosure something like: 8E9 035 382 B or C
    biyitch's Avatar
    Southampton
    300
    Quote Originally Posted by no_idea View Post
    You have a PM.
