Results 1 to 10 of 10
    sebhar70's Avatar
    Apr 2009
    South London
    200
    HELP-00542 G80 needle lift sensor error code
    Visited Audi dealers recently and this code appeared on the diagnostic, engineer states that the lift sensor in the number 3 injector is faulty and will cost Ł615.49 to replace. I think they will need to replace the whole injector unit. Anyone had this happen before? Is there a cheaper option?
    staggspeed's Avatar
    staggspeed
    Sep 2009
    somerset
    56
    Had this happen about 5 years ago on a seat alhambra, the hall sensor is part of the injector, so the whole thing had to be replaced,i seem to remember it cost me about Ł125 back then.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    The wire to the needle sensor in the injector is prone to rubbing through on the cam cover and shorting, I would make sure they check that first off.
    sebhar70's Avatar
    Apr 2009
    South London
    200
    Was that for the whole injector unit (new) or was you able to recondition?
    sebhar70's Avatar
    Apr 2009
    South London
    200
    Ok will do
    staggspeed's Avatar
    staggspeed
    Sep 2009
    somerset
    56
    reconditioned if i remember correctly,but james is spot on,check the wire first.
    Mar 2008
    Dorset
    13,856
    I thought I had this issue last year and it was the wire, I can't remember the quoted price of the sensor (maybe Ł160 ish?), but its only built into an injector from memory, so Ł615 is ridiculous!
    staggspeed's Avatar
    staggspeed
    Sep 2009
    somerset
    56
    definitely built into the sensor James,I remember thinking at the time what a dumb idea that was,it would keep going into limp mode,turn it off start it again and it would be ok for a while.
    sebhar70's Avatar
    Apr 2009
    South London
    200
    Is it easy to check the wire? can I do it myself?
    staggspeed's Avatar
    staggspeed
    Sep 2009
    somerset
    56
    just check the insulation has not worn through earthing it out.
