JMB RetrofitsAH Fabrications
Results 1 to 7 of 7
    London
    160
    Angry Multitronic gearbox losing gears
    hi every one
    my mate has brought a 2004 audi a4 1.9 tdi with a 6speed multitronic
    gearbox
    and he seems to be losing gears totaly while driving
    checked the car with vag com and no faults cumming up
    been doing some research on it either its a ecu problem or complete
    gearbox screwed up
    anyone shed some light on this head **** car please.
    thanks
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,591
    has that had the clutch swapped over from 6-plate to 7-plate system?
    it's a known issue with the Multitronics that they can't handle the torque of the TDI's (they'll even struggle with an un-mapped 1.9TDI) and they had to recall all the 2.5TDI's!
    LostBok/BahnStormer77
    London
    160
    im not 100% sure but from what i can recall is that causes vibrations as such if you
    have clucth problems as such!!!
    it will drive faultless and then loss the gears.
    and at times i noticed the light on the gear selector for your foot brake does not
    work and then it does work
    London
    160
    a4 2.4 se's Avatar
    V6
    Aug 2006
    Leicester
    110
    poss ecu fault try this http://ecutesting.com/audi
    Nov 2005
    Midlands
    215
    Vinlane you have posted the same ad on 3 threads....
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,696
    Yes, and shouted very loudly too.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
