Results 1 to 10 of 10
    PMJ
    need another DTM
    Sep 2009
    Berkshire
    51
    Hope this isn't the start
    Had an issue this morning.... Driving to work at a speed that can only be called illiegal, came off the motorway and got onto a side road... the car was running like it was only firing on 3 cylinders... got into the car park at work at it was idling so badly it was almost stalling.... had a quick look under the bonnet checked leads and wiggled the usual stuff but could not see anything obvious, anyone point me in a direction to look further at.... the car is A4 2.0t on an 06 plate...
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    That will be a B7 then, I would suspect a coil pack is on the way out.
    PMJ
    need another DTM
    Sep 2009
    Berkshire
    51
    Not good, the car only has 30k on it.... but it was driving it hard....seemed OK on the way home but was driven properly
    howdy quattro's Avatar
    Dec 2007
    boston, lincs
    318
    Freezing weather = poorly coilpacks! I've had 3 go this season!
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,522
    Common fault sadly, cheap enough to fix, under 30 per. Prob worth buying a spare one
    kite's Avatar
    Oct 2007
    East Berks
    675
    Vagcom scan will tell you if its missing and which coilpack has failed...
    Audi A4 S-line Avant 2.0T FSI
    Mar 2009
    Stevenage
    289
    If it was already being driven and engine compartment warmed up etc, would the weather really cause an issue with this component?
    If it's got t*ts or wheels, it's TROUBLE!
    PMJ
    need another DTM
    Sep 2009
    Berkshire
    51
    I had th diagnostics put on it and it came up with the following
    08801 P2261 008
    Air recirc.valve for turbocharger - N249 , mechanical fault.
    Again I am told that this is common, one thing I am finding is that there are alot of common faults with the A4, 20 for the part and 70 in labour plus vat... thats alot of money for a sticking valve that has been ok for the last two days...
    Dec 2007
    boston, lincs
    318
    If its just a case of taking the old one out and replacing it why not do it yourself mate? Ask a techy before hand if anything else needs to be done as well as just plumbing it in, I know its not vag stuff but with the newer mercs once you fit stuff, even stuff like injectors you have to code them into the ECU so it recognises them. Might be the same with the recirc valve on your a4, if not then have a go yourself and save yourself 70 quid!!
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    I bet its easy enough to fit aswell.70 +VAT, cheeky B...........ards
