AH FabricationsSky Insurance
Thread: HID fitting
    Dec 2009
    37
    HID fitting
    I have a 2003 A4 3.0 quattro sport and want to fit an after market HID kit, iv had a brief look into this and i see some kits give problems.
    Can anyone recomend a kit that will work 100% and not give me bulb failure problems? i take it i will need a kit that has the can bus?
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Search this forum for HID or Xenons - it's been covered many many many times before.
    Here is some HID work I've done: Slimline HID's in Headlights.
    To clarify - kit claiming to be CAN-BUS compatible - a further confusion.
    Retrofit kits do not use the CAN-BUS interface at all. What kits "may(???)" do is interfere at SWITCH-ON with the Crash Sensors near the front of the car mounted either side of the radiator - may give "Check Brakes" on the DIS, log scrambled data on the car ECU, etc.
    Some kits may also pop-up "Bulb Failure" warnings on the DIS and may offer a fix by providing a shunt resistor to fool the car into thinking it has a higher wattage bulb - that's because HID's take less power than halogen bulbs. You should not need shunt resistors if you get the right HID kit.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    pjmspeedy's Avatar
    Dude, what's mine say ?
    Apr 2008
    North West
    1,057
    Read this thread
    HID'S
    Audi A4 1.8T Sport Cabriolet-Full black leather(Electric & heated),RNS-E,BOSE, OEM Bluetooth,RS4 Mirrors,RS4 FBMFSW,RS4 Pedals,RS4 RARB,Cruise Control,B7 Rear Lights,Ally Inlays,18" RS6 Alloys,HID's/Auto lights with dimming rear view mirror,Coming home lights,Ambient light pack & Rear parking sensors.
    For all your VAG OEM PARTS send me a PM or e-mail me at vagoemparts@ymail.com
