Chris NottSky Insurance
Page 1 of 3 123 LastLast
Results 1 to 40 of 96
    chrisash32's Avatar
    Manchester
    575
    Anyone done a Cruise and DIS Retrofit?
    Hi All!
    Just got all my parts to do the DIS and Cruise Retro fit!!! Excited! and worried at the same time!
    Just wanted to know if anyone else on here had done it themselves that i could pester / PM for advice if anything goes up the wall with mine...
    If not that.... just any advice before i start.
    Cheers!
    Chris
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,578
    not done it myself... I've got some good cotacts who will come to your house and tidy it all up for you if it goes horribly pear-shaped.... but that said, maybe not best to try until 4th Jan so the clean-up crew will be able to get to you
    LostBok/BahnStormer77
    chrisash32's Avatar
    Manchester
    575
    Quote Originally Posted by lostbok View Post
    lol, clean up crew on standby sounds good!
    just missing one or two tools now and thats it! Its the programming side thats worrying me more than anything i think!
    oh.. and i am going to stand well clear when i re-connect the battery after refitting the air bag!!!
    technics100's Avatar
    Feb 2004
    Co Antrim
    771
    I did just the DIS install, took a couple of hours and all went smoothly enough. I think adding the cruise is just a matter of fitting the stalk and SWCM and doing a bit more coding. The scariest bit it removing the plug from the airbag...
    here is my write up on it..
    DIS Retro-fit Question
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    chrisash32's Avatar
    Manchester
    575
    Quote Originally Posted by technics100 View Post
    thanks!
    In your thread you mention this URL:
    http://sites.google.com/site/ade2ade/a4-cruise-coding
    Now, i cant seem to get that to work in any browser.. the page loads fine but the drop down box's to work out codes etc etc just don't work.
    Is it the same for anyone else?
    Chris
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    yep, same for me.
    chris, get it fitted mate, we'll sort your coding out between us on here.
    i retro fitted my cruise, doddle mate, did you get the two tiny threaded screws with it?
    are you sure the rest of it is compatible, ie: module etc.
    LOTS DONE, LOTS SPENT !!!!
    A4 nut's Avatar
    wolverhampton
    352
    Allways wanted to do a cruise on mine anyone got a stalk nocking about. dont you need a new steering column cowling
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    nut, you do but its not essential, on the one youve got, if you remove it you will see a line where the cut out should be, a two minute job to cut it out yourself and save 25, really easy job mate.
    do you have a multi wheel, you may need a new module to add cruise.
    i upgraged mine when i changed my sterring wheel to a FBMFSW.
    chrisash32's Avatar
    Manchester
    575
    Quote Originally Posted by 1wheelonly View Post
    yep, same for me.
    yep, got a new module and the screws etc etc...
    Just about to start mine now...
    Wish me luck as my vag-com has just started playing up too!!!! eeeep!
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    youll be fine, if your stuck, give me a shout and ill plug in and go through it with you
    chrisash32's Avatar
    Manchester
    575
    thanks
    are you local to me? (South Manchester)
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    no im in the midlands but you can have my number and ill plug into my car and go through the codes with you over the phone whilst your plugged in your end to your car, or you can scan it and post it up on along with the bits your fitting and we'll sort the codes for you.
    chrisash32's Avatar
    Manchester
    575
    Thanks, well i am half way through the fitting at the moment! Just done Pin 1 on the clocks and put it ready to do my bottle with tomorrow.
    Going to hopefully get it all coded up tonight all being well!
    Any idea what my login would be for the ABS?
    Audi A4 1.9 TDi Sport Avant?
    I will PM you my number..
    Thanks a lot!
    Cheers!
    Chris
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,722
    Just out of interest, how much has this cost you chrisash? I'm considering cruise, but already have dis. How's it all going?
    chrisash32's Avatar
    Manchester
    575
    hmmm
    It doest seem to have gone swimmingly well...
    All is fitted ok... and DIS is active...
    However it just does not seem to be coding correctly...
    Here are my faults:
    Thursday,24,December,2009,21:33:50:26365
    VCDS Version: Release 805.0
    Address 01: Engine
    Control Module Part Number: 038 906 019 LJ
    Component and/or Version: 1,9l R4 EDC G000SG 4910
    Software Coding: 00002
    Work Shop Code: WSC 63251
    Additional Info: WAUZZZ8E54A160115 AUZ6Z0C0406934
    2 Faults Found:
    17977 - Cruise Control Switch (E45): Implausible Signal
    P1569 - 35-00 - -
    18097 - Powertrain Data Bus: Implausible Message from Elect. Load Controller
    P1689 - 35-00 - -
    Readiness: 0 0 0 0 1
    Thursday,24,December,2009,21:34:59:26365
    Address 03: ABS Brakes
    Control Module Part Number: 8E0 614 517
    Component and/or Version: ABS/ESP front 3429
    Software Coding: 00000
    Work Shop Code: WSC 00000
    2 Faults Found:
    00778 - Steering Angle Sensor (G85)
    66-10 - Not Matched - Intermittent
    01044 - Control Module Incorrectly Coded
    35-00 - -
    Tried to code it 5 - 6 times now on the ABS side of things... all goes ok, and on the last step where it says faults should be cleared, they are..
    however warning still stay son dashboard and when i restart the car all the same fault codes for ABS come back.
    As for the engine fault codes... cruise control works fine, so i don't know what its problem is..
    I have driven for 4 mile to see if the faults disappear on their own and they don't
    HELP!! Ideas?
    Cheers!
    Chris
    Sep 2003
    Bournemouth
    312
    The abs module hasn't taken the coding mate
    FOR SALE... 2007 Rns-e (sds), 2009 OEM bluetooth module, Flat bottom TTRS MFSW, steering wheel control module and slipring. All in Classifieds, Pm me if interested.
    RS6 Avant, Milltek non res, Forge, ITG, Bilstein, Hotchkis.
    chrisash32's Avatar
    Manchester
    575
    Quote Originally Posted by BILKO1 View Post
    yeh, no matter what i try its just not taking it
    Sep 2003
    Bournemouth
    312
    What version of vagcom software are you using? do you have a genuine VCDS not an ebay special.
    chrisash32's Avatar
    Manchester
    575
    HaHa.. 805.0... is my cable genuine? Sore subject... In short i don think so.. Although it was sold to me as genuine and i paid a rather large sum of money for it..
    After about 5 use's it popped up once or twice with "unlicensed interface" which at first i thought was because it was on a mac. but i wanted to know for sure, now the guy i bought it from cant be found for love nor money.. So i think i have been done over on a none genuine lead..
    Do you think that could be my issue? as i don't really have any problems with it..
    Guess i need to spend another 200+ and get a lead from a reputable supplier?
    Chris
    Sep 2003
    Bournemouth
    312
    Try the latest version here http://www.ross-tech.com/vcds/download/
    chrisash32's Avatar
    Manchester
    575
    hmmm thats not working.... i guess thats confirmed my suspicions...
    chrisash32's Avatar
    Manchester
    575
    anyone got a genuine vag-com near me? South Manchester / Cheshire?
    That wouldn't mind having a shot at this for me in exchange for beer like favours??
    Chris
    Sep 2003
    Bournemouth
    312
    Try posting here mate http://www.audi-sport.net/vb/showthread.php?t=84603 should get a better response.
    chrisash32's Avatar
    Manchester
    575
    All fixed guys
    BahnStormer
    Feb 2009
    Surrey
    2,578
    nice work!
    just checking - do you have the RNS-E sat nav?
    chrisash32's Avatar
    Manchester
    575
    nice work!
    No, not got the RNS-E, why?
    Would like it though!!
  28. #27
    BahnStormer
    Feb 2009
    Surrey
    2,578
    Quote Originally Posted by chrisash32 View Post
    no worries - was just gonna ask how the switching between DIS and SatNav directions on the DIS screen was working for you... there can be some probs.
    well worth the upgrade - really sharpens up the whole interior and integrates in with the rest of the Audi kit very well!!
  29. #28
    chrisash32's Avatar
    Manchester
    575
    yeh, i really want to upgrade mine.
    question though... how come some of them have a lip between the RNS-E and the Climate unit and then some of them done (flush fit)...
    Is this a bi-product of a retrofit?
    Chris
  30. #29
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    do you mean the climate is set back in further than the rns-e, i thought they all were, dont recall seeing any with the front faces all flush, i may be wrong, just havent noticed, my climates deffo set back from my rns-e, theres a chrome strip at the bottom of the rns-e that rounds under and stops level with the face of the climate, cant see how it could be flush.
    heres a pic of mine.
  31. #30
    BahnStormer
    Feb 2009
    Surrey
    2,578
    not sure if that is a product of the retro-fit, but mine definitely has a step.... never noticed it before.... never even knew it should be a flush fit..... bah!!! I will know now!
  32. #31
    chrisash32's Avatar
    Manchester
    575
    gimme 5, will gab some pics i seen earlier online of OEM vs Retrofit..
    that interior on the cab is stunning btw!! Love the Steering wheel, thats exactly what i want!!
  33. #32
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    losty, yours is more or less identicle inside aint it, no wait GET SOME PEDALS !!! lol
  34. #33
    BahnStormer
    Feb 2009
    Surrey
    2,578
    ha ha.... now go away!!!
    already got a quote from pjmspeedy and the part numbers all lined up... will probably have them in once the March bonus comes in... (fingers crossed)
  35. #34
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    chrisash, not convinced buddy, the chrome strip underneath the stereo wouldnt let it sit flush, also lostys is exactly the same.
  36. #35
    chrisash32's Avatar
    Manchester
    575
    i am doubting myself now.. just trying to find the photo's that i was looking at earlier...
  37. #36
    chrisash32's Avatar
    Manchester
    575
    found the photos, looks like they were actually from an old shape A6....
    Ignore me
  38. #37
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    losty, are you getting the deadman aswell, make sure you get the right one mate, alot of left hand drive ones about, and they aint cheap.
    chris, dont worry to much mate,cause if you do find it and and it looks better, then thats going to cost us all more money lol
  39. #38
    chrisash32's Avatar
    Manchester
    575
    lol, you win! How much are the peddles btw? Oh and the Steering wheel mod?? ah, and the RNS-E... uh oh.. this list is going to be endless!
  40. #39
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    pedals are about 70 inc postage, that dont include the deadman, about 110 with that.
    rns-e can be got for around 400 - 450, if you have single din stereo you need to change cage to double din about 50.
    fbmfsw, thats a different story, module and slipring requires changing, plus cost of wheel and airbag, that can get very expensive, wouldnt want to tell you what mine cost, youd be to jealous, lol bargain.
    obviously all the above require fitting, which arent hard to be honest, just depends how handy you class yourself.
    without doubt, the pedals are the worst to fit, there a ******* !!!
  41. #40
    chrisash32's Avatar
    Manchester
    575
    I have to ask one thing... what the hell is "the deadman".... loll
    I have just changed my SCCM to one of a B7 that supports MFSW, so that shouldn't be an issue.. However its the whole dual and single stage airbag thing that worries me..
    I seen a wheel go on eBay, christmas eve for 46 including bag... Exactly what i wanted too. Just this stuff about the newer wheels not working with the older cars air bags etc etc put me off, so i left it!
