hmmm
It doest seem to have gone swimmingly well...
All is fitted ok... and DIS is active...
However it just does not seem to be coding correctly...
Here are my faults:
Thursday,24,December,2009,21:33:50:26365
VCDS Version: Release 805.0
Address 01: Engine
Control Module Part Number: 038 906 019 LJ
Component and/or Version: 1,9l R4 EDC G000SG 4910
Software Coding: 00002
Work Shop Code: WSC 63251
Additional Info: WAUZZZ8E54A160115 AUZ6Z0C0406934
2 Faults Found:
17977 - Cruise Control Switch (E45): Implausible Signal
P1569 - 35-00 - -
18097 - Powertrain Data Bus: Implausible Message from Elect. Load Controller
P1689 - 35-00 - -
Readiness: 0 0 0 0 1
Thursday,24,December,2009,21:34:59:26365
Address 03: ABS Brakes
Control Module Part Number: 8E0 614 517
Component and/or Version: ABS/ESP front 3429
Software Coding: 00000
Work Shop Code: WSC 00000
2 Faults Found:
00778 - Steering Angle Sensor (G85)
66-10 - Not Matched - Intermittent
01044 - Control Module Incorrectly Coded
35-00 - -
Tried to code it 5 - 6 times now on the ABS side of things... all goes ok, and on the last step where it says faults should be cleared, they are..
however warning still stay son dashboard and when i restart the car all the same fault codes for ABS come back.
As for the engine fault codes... cruise control works fine, so i don't know what its problem is..
I have driven for 4 mile to see if the faults disappear on their own and they don't
HELP!! Ideas?
Cheers!
Chris
