Volks AutosChris Nott
Page 3 of 3 FirstFirst 123
Results 81 to 96 of 96
  1. #81
    A4 nut's Avatar
    wolverhampton
    352
    The coding is 01041 but went into 09 central electrics and had the fault that the module was not coded with the vin could this have anything to do with it.
  3. #82
    May 2007
    Chorley, Lancs
    781
    Hi all...
    I have Cruise Control & DIS on my Audi A4 B6 Avant.....and I had to change the SCSM for one that also supports Multi Function Steering Wheel.
    So I have a spare SCSM that does support both DIS & Cruise Control.....(But NOT MFSW)
    Part Number is 8E0 953 549P
    PM me any offers before I stick it on flea-bay
    Monza Silver A4 2.0TDi S-Line Avant Quattro (170) - Heated Alcantara Leather, Sat Nav, Bluetooth, Folding Door Miirrors, Electric Tailgate, Privacy Glass, etc
  4. #83
    chrisash32's Avatar
    Manchester
    575
    Quote Originally Posted by A4 nut View Post
    Ah, that will explain things... however without this corrected it shouldn't have let you code up the ABS Module etc etc.
    If you clear that fault does it come straight back?
    I assume you are getting that error as your module came off a different vehicle?
    If it doesn't clear when your try, drop me a PM and i will explain how to code it.
  5. #84
    A4 nut's Avatar
    wolverhampton
    352
    What is this wire that wiki says to install where does it go?
    Installation & Wiring
    In general the whole retrofit is just plug and play except that one wire needs to be added.
    • Wire T16a/5 from steering column control module to engine control module (see wiring diagram specific your particular car/engine).
    • Install cruise control capable lever (see parts catalog/repair manual).
    Who has done this i dont read about this in the forum?
  6. #85
    chrisash32's Avatar
    Manchester
    575
    Didnt do that on mine, are you sure the wiki you are reading is for a B6? As that sounds like what has to be done on the A2.
  7. #86
    A4 nut's Avatar
    wolverhampton
    352
    That is the only information for A4/S4 retro fit on wiki it comes under 8e cant find anymore info on it so take it the wire does not have to be done.
    still cant get my cruise to work just clutching at straws, under steering wheel the fault code says module not coded correctly. i think it hasnt learned the vin of the car as it wont accept it, go into addaption channel 081 enter 00111 as value test and then save but then in the top left it comes up (bus not ok) what am i doing wrong any ideas?
  8. #87
    chrisash32's Avatar
    Manchester
    575
    Have you gone through the entire procedure start to finish again?
    Its took me a few attempts to crack it over 3 days! I was putting the wrong code in....
  9. #88
    A4 nut's Avatar
    wolverhampton
    352
    Yes gone from start to finnish been at it in my spare time since christmas and gone through 2 swcm in trying ,have been reading that some people need the module for the mfsw to get theres to work even though they dont have one. Is it different coding for cabs? ill get there in the end The module i have is 8eo-953-549-N this should work so i must be doing somthing wrong could do with a definate proceedure instead of picking out bits from forums.
    Hope the people that took me DIE
  10. #89
    chrisash32's Avatar
    Manchester
    575
    The N module will be fine! Where abouts are you? Might just need someone else to have a go at it
  11. #90
    A4 nut's Avatar
    wolverhampton
    352
    Wolverhampton, westmidlands if anyone is near and can help pm me
  12. #91
    chrisash32's Avatar
    Manchester
    575
    I visit MK a fair bit... That any good to you?
  13. #92
    A4 nut's Avatar
    wolverhampton
    352
    I could make that but not for a few weeks due to work, Thanks for the offer ill pm you if i dont get it sorted this weekend cheers
  14. #93
    chrisash32's Avatar
    Manchester
    575
    In the meantime, PM me the results of a full scan.
  15. #94
    iyrix's Avatar
    Mar 2010
    427
    Hi Guys,
    Just read this whole thread and im now really interested in retro fitting DIS and CC.
    If i can buy all three stalks in the one unit would that be best? I've found the CC stalk and the DIS on the wipers for 45. Was not sure if that was good or not?
    Graham
  16. #95
    boya's Avatar
    Aug 2009
    consett county durham
    394
    Quote Originally Posted by iyrix View Post
    Hi Guys,
    Graham
    hi, sorry for the thread hijack, i have parts for sale in the classified section on here. check it out
  17. #96
    vrbob's Avatar
    Jun 2007
    Southampton
    2,362
    Right just bought the bits of Boya (cheers mate) so once they arrive and my VAGcom cable finally shows up so will be back for some coding help to fit my DIS and Cruise Control when everything has arrived and its not raining outside.
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
