Hi Jason,
I am just about to order all the parts today to do this on mine.
But i am also going to fit cruise control at the same time.
If you don't want cruise, its a fairly simple job and you will only need the right hand stalk (About £70 from pjmspeedy on here).
I would put the part number on, however it depends if you have a Saloon or an Avant.
If you do want cruise as well, but don't have a multi function steering wheel... you will also need a new steering wheel control unit. (this is where it gets slightly complex) as the standard one without MFSW does not support cruise or MFSW. Not impossible though, just a bit more expensive.
