AH FabricationsJMB Retrofits
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,265
    Red light in door not red
    Does anyone know how to access the red light in the rear drivers door to change the bulb?
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Quote Originally Posted by swarcup View Post
    Do you mean the one that is on the door edge to warn other cars your door is open?
    If yes - pull it out, or use a wide flat blade screwdriver to gently prize it out. Simple sprung plastic clip that is part of the lens and is along the short end of the light.
    They also automatically switch off after ~10mins or so when you leave the door open so bear this in mind once you've changed the bulb!
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,265
    thanks for that
    its deffinately blown so il wip it out now (ooh er)
