AH FabricationsJMB Retrofits
Page 1 of 2 12 LastLast
Results 1 to 40 of 53
    SmoothAssault's Avatar
    Will design for mods
    Dec 2007
    Cambridgeshire
    790
    B5 RS4 Brake upgrade checklist...
    Hi Guys, I just picked up my RS4 calipers and carriers from my friendly neighbourhood powder coater; they've come out fantastic! Couldn't be happier and so will finally be fitting everything Friday night/Saturday.
    I've not done anything like this before, but I'll be working with a couple of guys who have to ensure everything's done correctly. I'm fairly sure I know what is involved and have been researching for a couple of months but to avoid calling the guys over only to find I'm missing a vital element, just thought I'd run this checklist past you guys...
    This is everything I have ready...
    • RS4 Discs
    • EBC redstuff pads
    • RS4 calipers
    • RS4 carriers
    • RS4 dust sheilds
    • HEL RS4 braided brake lines
    • Replacement seals, dust-boots and guide-pin bushes
    And still on my shopping list...
    • Brake grease/ copper grease
    • Brake cleaner (apparently for the discs?)
    • Brake fluid (DOT 5.1?)
    Open to recommendations on the brake fluid as my thinking behind DOT 5.1 is simply "it's a higher number, it must be better". I know I need to avoid DOT 5 as it's fully synthetic and can't be mixed with whatever is in there at the moment. I want the best but price is obviously a factor that needs to be considered. I'm hoping it's not like liquid gold!?
    Along with your standard workshop tools I've also bought...
    • 'Eezibleed' brake bleed kit
    • Caliper piston tool
    As I said I'm fairly sure about the whole process but I do have one grey area... When I disconnect the existing brake lines, surely I'm going to have fluid pouring out? So what would you advise I do about this? Let it all drain out and refill the whole lot? Or plug the line some how and just top the fluid up?
    If there's anything else I've overlooked please let me know.
    Thanks.
    If you're interested, my B5 RS4 brake rebuild thread is here...
    Calliper refurb kit?
    I'll be updating it this evening to show the sand-blasted parts and the powder coating.
    FOR SALE: Eibach Sportline Springs from B5 A4. £50 - PM for details.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    All sound good to me the hardest part will be bleeding the system, the rest is almost like doing a brake disc change.
    You do have the bolts to mount them on the calipers and carriers together!
    Dec 2007
    Cambridgeshire
    790
    I'm hoping the Ezibleed I bought will make bleeding a lot easier, but the guys I'm doing the job with are apparently seasoned experts in the old pedal pumping method if it decides to fail on me.
    I have the bolts. Stoaksey threw them in when I picked up the rest of the bits from him. I just hope they fit the B6!!
    Any thoughts regarding what brake fluid to go for?
    Cheers.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Stock will be fine.
    You would only realy need to upgrade if you was going racing, never had a sigle issue on my B5 running this set-up so you should be fine.
    Dec 2007
    Cambridgeshire
    790
    Up and down the A1 doesn't count as racing?
    Okay thanks for that. Actually, come to think of it... what is the stock fluid exactly?
    stoakseya4's Avatar
    Aug 2005
    Kent, UK
    1,227
    Any DOT 4 fluid from Halfords will be fine for general road use.
    I'll be changing to Motul 600 DOT 4 fluid shortly. This is better than 5.1 fluid, as recommended by MRC Tuning, as it has a higher temperature rating.
    HTH
    1998 S4 Widebody Saloon Track Car
    2006 320d SE Touring - Ze Fuhrer's Wagon
    2001 B5 RS4 510bhp & 508ft lbs SOLD
    1.9TDI (130) Sport -Black-Revo - Mrs Stoakseya4's mota - SOLD
    Dec 2007
    Cambridgeshire
    790
    Cheers Carl
    stoakseya4's Avatar
    Aug 2005
    Kent, UK
    1,227
    No worries, mate. Looking forward to seeing how they come out!
    Dec 2007
    Cambridgeshire
    790
    Okay, I assembled everything last night. Getting the pistons in took absolutely ages, but I got there in the end.
    I put the pads in place to check I knew how everything was going to fit together. Looking good so far...
    Woke up at the crack of noon ... Took my car over to the garage and checked the calipers were working with some compressed air (blocked them with a piece of wood so they didn't pop all the way out).
    I undid a brake line and let the fluid drain into a container. Then made a start on the epic ball ache that is removing the old brakes. The carrier bolts were a ***** but with those finally off, removed the caliper and tapped off the disc with a rubber mallet, then removed the old shield.
    Cleaned up the hub with a brush and started fitting the new brakes. Approaching 6:00pm by now and decided to just bolt everything on, get the wheel on and finish the job tomorrow.
    Here's how they look...
    Pretty tasty. Lots to do tomorrow though; the same for the drivers side, fit the rear braided lines (came with the set, may as well use them), bleed the clutch, then all four corners in whatever the sequence is.
    ...and if it's not finished by Monday, I'll be walking to work.
    filthyrich's Avatar
    slipper wagonz
    Apr 2009
    47
    Nice....
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Tomorrow you will have a big grin.
    Dec 2007
    Cambridgeshire
    790
    lol... or a long walk Monday.
    Everything went pretty well today. I started off with the wrong brake line in the caliper but soon realised the ones with the banjo fitting were for the fronts and swapped it over. That was the only error so far.
    The shield does not seem to sit parallel to the disc. Is this normal? the disc is definitely sitting flush on the hub but the shield pulls away from the disc at the top. All is secure but wasn't sure if this was normal and was my only other concern.
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    ...You wont be going anywhere monday mate, You'll still be in A&E waiting to be seen after that nasty NUT you gave your Steering wheel..
    Looking well matey! Better pics tomorrow though yeah
    Dec 2007
    Cambridgeshire
    790
    lol, cheers Juss. Definitely better pics tomorrow (providing it is still light when/if I finish).
    Think the most likely cause of me being in A&E tomorrow will be a stress induced comma brought on by endless attempts at bleeding the clutch. Really not looking forward to that bit
    stoakseya4's Avatar
    Aug 2005
    Kent, UK
    1,227
    Shiney...
    Nice job.
    Dec 2007
    Cambridgeshire
    790
    looks like I won't be walking to work tomorrow!!!!
    Started working at 12:00pm finished at 8:00pm, went out testing everything for half an hour and then tidied up the garage till 11:30pm. Long day. Big job. Very pleased it is finished but too exhausted to appreciate what I've done. Time for bed.
    Here's some more photos...
    before:
    After:
    Massive job for a complete novice to undertake. Very happy with the result but could not with a clear conscience recommend anyone else with as little experience as me try this. It is a very lengthy and involved job and you need an extremely good understanding of the brake system... Not to mention a garage full of tools!
    I'm sure when I regain consciousness I'll be quite proud of myself, but right now all I can think about is getting some sleep!
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    well done my man somewhat shocked it took so long with all the help you had but then when it comes to brakes it better to be safe than sorry. Nice job.
    Dec 2007
    Cambridgeshire
    790
    Yea, getting the carrier bolts off is like hitting a brick wall. And we would check and double check everything at each stage. We were very careful, probably over cautious! But given my limited (zero) experience I didn't mind taking my time with it.
    stoakseya4's Avatar
    Aug 2005
    Kent, UK
    1,227
    Look great...
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Nice Work Smooth.They look Massive, bigger the better eh!
    So hows the Braking then?? Shaaaaarppp
    Dec 2007
    Cambridgeshire
    790
    lol, yea, pretty much. I got them 70% for the look and 30% actual braking improvement. Really happy with them. Still bedding the pads so being careful not to hammer them too hard, but it certainly feels a lot better under foot.
    Only thing I'm not happy with are the spring clips. Was gonna powder coat them hot pink but decided it would clash with the pads, so sprayed them with silver hamerite last minute. I don't think it looks right. Will change them soon.
    61
    Sorry to bring up an old thread but I have a quick related question - is that a B5 RS4 or B7 RS4 brake line?
    Thanks.
    Dec 2007
    Cambridgeshire
    790
    I used braided B5 RS4 lines.
    Mar 2012
    20
    Quote Originally Posted by SmoothAssault View Post
    Hi, I'm new to this forum. I have just got a set of these calipers from e-bay for £50. I plan to have them re-furbed by Big red, unless there are any better re-furbishers out there?
    I have a couple of questions :-
    1) do I need new shields (splash guards) or will the old ones do?
    2) I plan to get HEL RS4 brake lines and want to make sure I get the right ones, so when I order these are they year specific, or is there a part number I need to quote?
    Many thanks in anticipation of a reply!
    A4 B6 Avant 1.9 TDI Quattro
    Premier Tuning Stage 2 re-map
    RS4 18" Alloys
    HID headlights (5000k 55w) and fog lights (4300k 50w)
    Dec 2007
    Cambridgeshire
    790
    Wow, this was a long time ago. I bought the RS4 shields along with the callipers, can't remember if you could get away with leaving the stock B6 ones or not, never crossed my mind.
    I believe I got the HEL lines too. They were just listed as B5 RS4 braided lines. But if you need the year then I guess the B5 was 1999-2001. They may also refer to the B5 as the 2.7 twin-turbo or bi-turbo.
    I hope you also have the RS4 carriers to match the callipers? You'll need those.
    Big Red are good guys, I refurbed my brakes myself but bought all new bushes and seals from them - way cheaper than audi. And FYI, I just recently had to replace my discs - £250... each! Had to go with OEM, couldn't find any alternatives. Red Stuff pads were around £120 too.
    Still really pleased with the whole setup, even if the infamous RS4 tax does sting when things need replacing.
    Mar 2012
    20
    Thanks for getting back to me. Yeah, got the carriers with the calipers, sent the lot off today to Big Redd.
    I found Brembo Discs on ebay , which i intend to buy soon FRONT BREMBO BRAKE DISCS AUDI A4 (8D2, B5) 2.7 BI TURBO QUATTRO 98-98 | eBay
    Please tell me they are the right ones!
    RS4 18" Alloys
  28. #27
    Dec 2007
    Cambridgeshire
    790
    Those seem spot on mate. Wish someone had told me I could have got brembos!! I asked a few so-called "specialist" garages and they told me they'd only be able to get OEM. At least I know for next time, thanks.
    Looks like you've got everything covered, but if you can find the RS4 shields I'd get them. Just think, by using those discs instead of OEM ones you've saved £390 anyway, can probably pick up a pair of shields and still be getting a bargain.
  29. #28
    Mar 2012
    20
    I'm glad that these discs are OK....£500 for Audi one's, no chance I'll do a test fitting once I have everything back, to make sure the original guards are OK before "splash" out on RS4 one's
    Can you confirm there are the correct lines? Audi B5 RS4 Brake Lines by HEL Performance
    Cheers again!
    RS4 18" Alloys
  30. #29
    ASHIHARA's Avatar
    Mar 2011
    LONDON
    251
    Quote Originally Posted by Puppy View Post
    That brake discs are for S4 B5,not RS4 B5!,so they are not right ones!
    B6 1,9TDI AVF SPORT QUATTRO AVANT
    Mods:RNS-e sat nav,Bluetooth,Rear camera,Full led interior/exterior,Cobra PCD,S4 B5 front brakes,S line body kit+S4 door blades,S line gear knob,RS4 B7 handbrake,RS6 wheels,EGR deleted,cruise control,custom leather & alcantara seats,tinted windows,A4 B7 arms & wiper blades,BV43 turbo,FMIC,custom remap(around 200hp and 368lb/ft tourque)
  31. #30
    Dec 2007
    Cambridgeshire
    790
    I'm fairly sure those brake lines are exactly what I bought. Have fun
  32. #31
    Dec 2007
    Cambridgeshire
    790
    Quote Originally Posted by ASHIHARA View Post
    Why do you think they're not right?
    2.7 Bi-turbo quattro, 360mm diameter, 30mm thick, radially vented? I'm pretty sure that's what I'm running. Though was surprised as three places did tell me that OEM was the only option.
    here's a listing for the OEM ones I'm running...
    Genuine Audi RS4 B5 2.7T front pads and discs | eBay
    Seem the same? Though do state till 2001 which is more accurate.
  33. #32
    Dec 2007
    Cambridgeshire
    790
    Just found another place claiming that 321mm fits the RS4. But almost certain that mine are 360 or 362, something like that.
  34. #33
    ASHIHARA's Avatar
    Mar 2011
    LONDON
    251
    In this link they are for S4 B5 321mmx30mm,not 360mmx30mm like RS4 B5.And 321mm dont fit rs4 calipers,there is a huge difference between them!
    I thing the confusion comes because bouth of them(s4 and rs4) have 2,7 bi-turbo engine.
  35. #34
    Dec 2007
    Cambridgeshire
    790
    Oh dear, maybe there really is no getting around paying for the £500 OEM discs. Puppy won't be pleased, I know I wasn't!
    Must admit, I read 2.7 bi-turbo and thought, "that's an RS4" - absolutely convinced. Had no idea the S4's ran the same.
  36. #35
    Mar 2012
    20
    When I got the calipers, I test fitted one to the car over the old discsAnd I measured every thing up and concluded that the 321mm discs were the way to go. Now I'm not so sure guys!Here is a link to the calipers I bought on e-bay eBay - The UK's Online MarketplaceThey are listed as from a
    8D5,B5 [1996-2001] Estate S4 quattro , and he got rid, as he was upgrading to RS4 calipers!!Just to confuse matters more, there are 321 mm Bosch discs on e-bay which list the RS4, amongst others in the fitments table
    2 x Bosch FRONT Vented Brake Discs Genuine Service Part No. BD882 / 0986478985 | eBaySo I'm well confused now
    RS4 18" Alloys
  37. #36
    Dec 2007
    Cambridgeshire
    790
    The plot thickens! As far as I can tell, those callipers look the same as mine - RS4. I know mine are definitely RS4 as they came off another member's RS4 who I met at Audi Driver International over at Castle Combe. He was switching to a Porsche Cayenne setup, and I had the whole stock RS4 setup from him.
    Here's what B5 S4 brakes look like, (nothing like yours)...
    :: a4mods.com :: - The Premiere Audi A4 Modification Guide and Pictures Library
    So I'd guess the seller just listed them as S4 by mistake, pretty easy typo I suppose.
    My discs are definitely 360mm. I've got a feeling ASHIHARA is correct, and that the confusion on the ebay listings is coming from both the S4 and RS4 having 2.7 bi-turbo engines (fooled me too).
    Here's some blurb from RS4's wikipedia page confirming the front disc size...
    Brakes were also developed jointly in house by Audi's quattro GmbH, not by Porsche as with its predecessor, the RS2. It has 360 millimetres (14.2 in) diameter by 32 millimetres (1.26 in) thick radially vented and floating cast iron discs at the front, with double-piston floating brake calipers, and 312 millimetres (12.3 in) by 22 millimetres (0.87 in) discs with a single-piston floating caliper at the rear, giving the RS4 braking to match, needing less than 50 metres (160 ft) to come to a full stop from a speed of 110 kilometres per hour (68 mph).
  38. #37
    Mar 2012
    20
    Thanks SA, I'm now sure I need the £500 disc's, but I ain't paying that.
    Plan B is S4 calipers, are these Audi A4 S4 2.7 Quattro Brake calipers £100 Cash Back | eBay the one's in the The Premier thread? I presume they go with 321mm discs?
    I may ask Big Redd if they will take the RS4's in part exchange for these!
    RS4 18" Alloys
  39. #38
    ASHIHARA's Avatar
    Mar 2011
    LONDON
    251
    Yes,that calipers are from S4 B5 321x30;i have the same setup,have a look here ,you have all the pics you need
    A4 B6 Quattro project
  40. #39
    Mar 2012
    20
    Nice one Ash, even if Big Red don't go for the exchange, I think I'll get them anyway. £290 is not bad for 2 twin piston calipers, and the 321 mm discs are much cheaper of course
    RS4 18" Alloys
  41. #40
    Dec 2007
    Cambridgeshire
    790
    I'll remain the only B6 owner in the world stupid enough to be running B5 fronts, haha.
Tags for this Thread
