Chris NottSky Insurance
    Dec 2006
    barnsley
    927
    Audi S4 gearbox oil change ?
    very confused about this
    my car is a 2004 s4 avant with tiptronic
    the engine code is bbk and the gearbox code is 09l
    i have asked audi technical if the gearbox oil needs either changing or topping up at any particular service
    ive been told it,s a sealed unit and doesnt require the oil changing or topping up at all
    but a lot of the american forums talk abut having theres changed
    has anyone any experiance of this please or can anybody find out what im being told is definately correct
    thanks
    nath
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Jun 2007
    56
    I have had my manual s4 for 3 years now and every time i take it for a service i am told that the oil shouldn't need changing (well known specialist)
    The RS6 boy's are told that there's doesn't need servicing in the manual but the torque converters fail early if they don't get a regular oil change. That could be due to the fact that theres some much power going through it to shift such a heavy weight that the oil heats up more.
    Try calling either MRC or UNIT 20. Both are very helpful
    Dunc
    Jul 2007
    London
    3,081
    Quote Originally Posted by dualmono21 View Post
    thanks
    nath
    The gearbox is "sealed for life" however the life of the box is much longer IF you change the oil and filter/strainer ! If you wanna be hit with a 5k bill soon, do not change it !
    technics100's Avatar
    Feb 2004
    Co Antrim
    772
    How many miles are on the box? some people say if its fine, leave it alone, as changing the oil can cause problems as you can't drain all the old old and when it mixes with the new oil it doesn't like it. I did an oil change on my S6 as I was having problems with it, didn't help and cost 1860 to get the box rebuilt, still had bother with it and sold the car on.. would out me off a tiptronic again in such a powerful car. maybe speak to a auto box specialist. Not sure if ZF make the box, but they have recommended installers in the UK. remember lifetime oil is just as long at the box lasts.. mine went at 83k.. its like saying engine oil is lifetime... but the lifetime will only be about 20k until it stops working!!!..
    some info about the A8 / S6 gearboxes
    http://www.audipages.com/Tech_Articl...servicing.html
    I think its the ZF 6HP19 gearbox in yours.. so find and speak to a ZF dealer, see what they say. They will say that oil changes are required, preferably at 40k intervals..
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    Dec 2006
    barnsley
    927
    car has done just under 50,000 and its running sweet as a nut
    no problems at all
    just a little concious especially when reading american forums
    ive asked my local specialist for a price for it to be done including filters and everything
    Feb 2004
    Co Antrim
    772
    Shouldn't be that much, I think the oil, filter o-rings etc is about 145 from Audi, make sure they use proper Audi fluid, its about 9 a litre, you need about 10 litres.. they should know how to do it right.. need to check the level with ATF below a certain temp etc..
