JMB RetrofitsVolks Autos
    Mar 2008
    117
    S4 Windscreen Washer bottle leak
    Hi, Noticed that my washer fluid level warning was on last night so thought I would top the bottle up, as fast as I was pouring water in the top it was coming out the bottom
    With it being dark I havent investigated whats happening but the washer system is working fine with whats left in the bottle so it isnt a pipe come of etc, whats involved in getting the bottle out? is this a common thing? we did have a hard frost last week not sure if this has split the bottle
    Car is an 05 plate S4 cab, thanks for any help
    Jun 2009
    Hi All, I have a similar problem.
    I can see the leak coming out of the bottom of the right hand side front wing (to the right of the wheel as you look at it). Anyone have any ideas where the leak could be coming from?
    Thanks in advance!
    Aron
    Jun 2007
    56
    The washer bottle is behind the nearside headlight. either one of the washer motors has come out or the bottle has failed. Not sure if the bumper has to come off to change the unit though?
    Think i saw a picture of one on here in a thread called "headlamp wash retro fit" or something along those lines.
    I'm sure someone will be along to help out properly
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    Get a soldering iron and just seal it up would be better if you had a old washer bottle around to help make the patch.
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Bumper does not need to come off.
    To take the washer bottle out remove the n/s front wheel and then the plastic wheel arch liner. The bottle has a top section and a bottom section with a rubber grommet sealing them together. My grommet had perished and required replacing - only noticed this when retrofitting Headlamp washers. Fitted a new seal all OK.
    Here is a PDF on washer bottle removal
    Headlight Washer Retrofit has some pictures Linked Here
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    Mar 2008
    117
    Thanks everyone for the responses, thats really useful Woorlord weather permitting I will have a go at the weekend and let you know what the problem was
    Cheers, Ken
