Results 1 to 7 of 7
    Feb 2003
    43
    It's Hot In the Cabin !
    Hi all,
    I wonder if anyone can confirm what i think i need to replace to solve my problem.
    Regually the blower will blow out hot air, no matter what the setting is unless it is set to low in which case it it is cold !
    I have found 2 errors via vag-com :
    00716 - Air recirculation Flap Positioning Motor (V113)
    41-10 - Blocked or No Voltage - Intermittent
    00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
    30-00 - Open or Short to Plus
    From what i have read if i replace the motor :
    8E2 820 511 D
    this will solve my cooling problems ???
    Many Thanks
    John.
    kite's Avatar
    Oct 2007
    East Berks
    659
    Drop the glovebox and see if the arms on the motors move, sometimes when jammed a gentle prod can get them going again.
    Feb 2003
    43
    Hi Kite, Yeah done that but all seems fine, movements ok. I dont fancy replacing a part that wont fix my problem.
    Many thanks
    John
    Sep 2003
    Bournemouth
    312
    I get the same codes mate and mine works fine. I clear them and they don't come back for weeks.
    FOR SALE... 2007 Rns-e (sds), 2009 OEM bluetooth module, Flat bottom TTRS MFSW, steering wheel control module and slipring. All in Classifieds, Pm me if interested.
    RS6 Avant, Milltek non res, Forge, ITG, Bilstein, Hotchkis.
    Feb 2003
    43
    Thanks BILKO1, But thats what i'm worried about.
    Can any one confirm that by changing the part
    8E2 820 511 D
    will cure my vents blowing out hot air on the passenger side ?
    Many Thanks
    Sep 2003
    Bournemouth
    312
    Is it the passenger side only? I'd do as said above remove glove box and phyically disconnect the motors (not the wiring) one at the at a time and move the flaps / rods manually until you find the culprit. Real easy to get at with the glove box out.
    Feb 2003
    43
    Hi BILKO1, When you say disconnect the motors not the wiring what do you mean ?
    Disconnect the plugs ?
    J
