EM TuningMonster Motorsport
Results 1 to 30 of 30
    Lancaster
    1,635
    Windows steaming up.
    Everytime i get in the A4 the windows are badly steamed up.
    I'm not used to this, the vectra i had before was perfect all year round.
    When it did play up, i'd just replace the pollen filter. I suspect this is the same in the A4?
    Where abouts is it, and is it hard to change?
    CHeeeeeeers
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    you really need to stop going dogging!
    the pollen filter is located in the top right corner of the engine bay next to the battery
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    hahaha @ Tech, Looks like theres some form tonight!!lol....nowt wrong with doggin mate
    have you made sure your recirc botton is switched off on your climate???
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    Quote Originally Posted by J7USS View Post
    was gonna mention that too, but would that affect it when its not running?
    really hoping its not a passenger footwell full of water causing the moisture build up
    Lancaster
    1,635
    ahh stop dogging, that would be cheaper but wheres the fun!
    Recirc isn't on, but my aircon isn't working atm as i tihnk its low on pressure. Hoping to have it topped up next week.
    I'll get a pollen filter ordered up and i'm sure it'll make a big difference. Its been sat at a garage for a lil while so i'm sure a damn good run on the motorway with the heaters at near on a thousand degrees will go someway to help.
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Quote Originally Posted by 1210tech View Post
    Oh yeah, Duhh, didnt read it properly...
    mind you, if you've just been out for a Blast (in your car, not doggin) and you switch off whilst on recirc, dont you sometimes get a little condensation especially when its been raining ....
    Or if it aint raining then if its as cold as it is in Leicester then Heat inside the car whilst this fooookin freezing will give off some moisture after switch off (...and not in your pants after Doggin BlackQuat )
    Lancaster
    1,635
    I always have a tissue i disgard of in public bins shortly after so it cant be that!
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    dunno, i never turn my recirc button on, i always have the full climate system running whatever the weather or amount of fuel left in tank!
    its set at 24 degress at the moment.....mmmmm, toastie
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    blakquat, almost forgot, make sure the ECON mode is switched off too (no red light), this puts the system into full climate control mode which dehumidifies the car while running
    Lancaster
    1,635
    Econ light is perm on, cant switch it off. I assume its low on pressure. Cant find anytihng in the service book about ti being topped up. So might nip it into Quickrip sometime.
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    thats the problem, the refrigerant needs topping up, i did mine myself earlier in the year using a diy can from halfrauds without any problems
    Lancaster
    1,635
    Ah yes! I remember seeing them, never thought about it with the vectra. Some what seemed pointless post hacksaw incident.
    Can you remember how much it cost fella?
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    this is the one i bought: EZ Chill
    it comes with a re-usable pressure gauge so u can tell how much is needed, mine actually needed a can and a half it had got so low but the difference after I had refilled it was amazing
    heres their website too: www.interdynamics-europe.co.uk
    Lancaster
    1,635
    Ah nice one fella, i may give that a go.
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    when u do the re-gas start the engine, set the temp on the climate control to 'LO' turn the fan up to full speed and then do the re-gas
    Lancaster
    1,635
    Do that whilst i charge it?
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    yeah, the engine and climate systems needs to be running while charging/re-gassing
    Lancaster
    1,635
    How do i do that if the econ button won't disengage fella?
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    the system is a full climate control system but while the ECON mode is switched on the air con system is turned off which means the dehumidifier isn't functioning.
    you can still set the temp to LO and fan speed to high, once the system has been charged the red light on the ECON will reset itself and you will be able to turn it on/off by pressing the ECON button.
    Lancaster
    1,635
    Trip to halfrauds tomorrow or sunday i think then!
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    you watch, they won't have any cans in stock cause its not summertime lol!
    Lancaster
    1,635
    Summertime. A unused word here in y....orkshu
    Thanking you muchly for your advice.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,708
    My windscreen steams up more when it needs a clean, bizarre I know. But if I clean the inside with AG Fast Glass or similar it eradicates it.
    Although I'm sure in your case it's down to the inoperative a/c.
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    no worries mate, i'll post a picture of the valve in the engine bay tomorrow. there are two pipes with valves right next to each other but the gauge will only fit the correct one for re-gassing
    Lancaster
    1,635
    No need fella, I saw em today when i had my headlights out to fit HID's So i'll save you the task. Thank you very much for offering though.
    So i'll get a can-o-gas and a new pollen filter and see how she goes from there!
    Apr 2009
    Shirley, Solihull
    542
    might be a better/cheaper option to get an aircon place to do it? i bought the ezchill stuff from halfords and also used nearly 2 cans (80 quid!) whereas most places will vac out/measure then regas for around 50 quid
    Available soon in the For Sale Section.....
    RS4 Pedals - Drivers side mirror mounting/wiring
    B6 Cab Front Grills - Drivers side B6 Cab Headlamp
    Moro Blue Mirror Caps - Full set of Cab Windscreen Surrounds
    Symphony 6 disc Head - Unit Full set of B6 Cab Manuals inc Leather Wallet
    N/S B6 Rear Lamp - RS6 Auto Brake Pedal
    PM for more details.......
  28. #27
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    Quote Originally Posted by markyzs180 View Post
    might be a better/cheaper option to get an aircon place to do it? i bought the ezchill stuff from halfords and also used nearly 2 cans (80 quid!) whereas most places wil avc out/measure then regas for around 50 quid
    x2
    forget all that hassle, sweet talk the Kwik fit gang and they'll sort you out. The chavs love a drink!
  29. #28
    Lancaster
    1,635
    bwahaha Kwik chav Fits.
    How much do they charge these days?
  30. #29
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    45 at the Kwiky near me.
    On a Saturday theres 4 lads that work there, eldest being about 14 by look of them and I got all 4 tyres swapped over to different alloys and they said just give the fitter a drink - so I did...20
    I use them all the time now along with a 'Drink'
    Im not saying dont go with the halfords route DIY but for how cheap it is these days, save the hassle and let the boys sort it out for you.
  31. #30
    Lancaster
    1,635
    Went today, i was abit wary of spending 45 on a recharge without checking it on Vagcom first, but then i thought it cant hurt to have it recharged and deal with any other problems.
    Anyway, after 143k it had gone very low and needed a regas, passed the pressure test and regased. ECON light isn't permently on now.
    25 quid. Great!
