Chris NottJMB Retrofits
    A4 Cabriolet 1.8T Owner
    Oct 2009
    Wisbech
    86
    Loud engine noise - CURED!!
    Well, after long persistance and checking things, i finally found my annoying noise, AIRCON pump!!!
    I didnt fancy spending loads of money on aircon in the winter, so got a smaller 6 ribbed belt, and by-passed the Aircon pump, job done!!
    Are these quite common tho?
    Also this is off topic, but my gf's A3 has ABS and ESP lights on, but we cant seem to track down the problem, checked all sensors, but still no luck!
    Daniel.
    Sep 2003
    Bournemouth
    312
    Aircon compressor is quite a common failure on Audi's i've had 2 go 1 on my B5 and 1 on my prsent B6. Cost about 300 for the compressor and also recommend you change the drier to, plus a regas.
    FOR SALE... 2007 Rns-e (sds), 2009 OEM bluetooth module, Flat bottom TTRS MFSW, steering wheel control module and slipring. All in Classifieds, Pm me if interested.
    RS6 Avant, Milltek non res, Forge, ITG, Bilstein, Hotchkis.
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,265
    abs and esp lights on can mean your brake light switch isnt working,
    hope this helps
