AH FabricationsJMB Retrofits
Results 1 to 19 of 19
Thread: ABS/ESP LIGHT
    markA4tdi
    Darlington North East
    105
    ABS/ESP LIGHT
    Hello all
    still got this problem with the abs/esp lights coming on intermittantly, having read a lot of posts on here they seem to affect the a3 alot, however mines an a4 (2002) has anyone else had this on their a4, and what resolved it,
    checked the brake lights all ok there, is it more likely to be the brake sense switch(at the pedal or a sensor on 1 of the wheels, (i was thinking if it was the abs pump it would happen all the time and stay illuminated). If its a check at the wheels, what should i look for?
    Aug 2009
    833
    does it come one when you start the car.
    then when you turn the car off and on again twice it disapears?
    markA4tdi
    105
    no just when driving along, dosnt happen all the time, i do the "check" button and all is ok at the end of the"check" wether they are illuminated or not (the abs/esp indicator bulbs).
    just took off the o/s/f and o/s/r/ wheels and nothing obvious there, unclipped the only unclippable connector, which im assuming is the brake pad wear indicator all ok there too, no dirt grease etc, so now going to check the n/s/f and n/s/r and see if all ok at that side too
    Aug 2009
    833
    remove the bulbs in the dash, problem solved!
    markA4tdi
    105
    Lol and heres me thinking, someones got the answer here! lol
    well had a look at the other side and all well there too, so how easy is the switch to remove? anyone done it?
    Jun 2007
    56
    Try posting your problem in the VCDS section to see if someone can do a scan for you.
    a4 2.4 se's Avatar
    V6
    Aug 2006
    Leicester
    110
    I had this fault on my A4 it was the brake switch cost about 12 from audi com fault
    markA4tdi
    105
    many thanks, only12 from audi, bonus, was it easy to fix/replace? how long to do?
    Jun 2009
    60
    I have the same issue
    light comes on -- usually after about 5 mins of driving -- stays on for maybe 3 mins then goes off
    always as above -- if it hasn't come on after 5-10mins it (i,m pretty sure) doesn't
    99% certain it started after I replaced my drivers side intercooler (about 3 weeks ago)
    markA4tdi
    105
    yeah pretty much same here regarding the times, turn off the ignition and everything ok, turn back on start up drive off all ok, then x number of mins later back on again, havnt tried yet to see if it affects the abs when they are lit up, i,ll have to hit the anchors hard and see,
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by markA4tdi View Post
    There's a PDF guide to do it HERE.
    Sep 2003
    Bournemouth
    312
    Quote Originally Posted by Nutkin View Post
    You will need a soldering iron as they are not conventional bulbs. I found this out when looking into an abs fault on a friends car he had no warning light. Turned out some dodgy garage put black tape over it to get it through an MOT
    FOR SALE... 2007 Rns-e (sds), 2009 OEM bluetooth module, Flat bottom TTRS MFSW, steering wheel control module and slipring. All in Classifieds, Pm me if interested.
    RS6 Avant, Milltek non res, Forge, ITG, Bilstein, Hotchkis.
    Aug 2009
    833
    Quote Originally Posted by BILKO1 View Post
    indeed im changing the leds on one over at the moment.
    markA4tdi
    105
    hmm so as its only the brake sensor switch, can i assume that the abs will still work then? or does having this light on disable the abs function?
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    Check the tail lights for a bulb out as this can also cause the problem.
    markA4tdi
    105
    finally had the vag com diagnosis, only thing that came up was the brake pedal switch! so off to audi and bought 1 today 8.81 so was quite pleased, came home followed the link and instructions on how to fit it andguess what!....... fixed? ...... nope.. arrrggh dont know what i did wrong if anything but when the new switch inpressed the pedal once all connected up, esp/abs lights on dash lit up but no brake lights! talk about gutted, after having been a contortionist in the footwell!! made sure all was connected still no brake lights , so put the old switch back in... brake lights on all the time! damn! so thought it best to switch back over and have no brake lights at all, going to have to swallow the dealers prices and book it in to get it done! but hey at least i tried....and failed lol!
    happy new year to all!
    A4 Cabriolet 1.8T Owner
    Oct 2009
    Wisbech
    86
    I seen this before, it was fixed by running it through basic adaption on the brake pressure sensor or steering angle sensor, as this can be reset by having the battery off too long or jump starting the car.
    Shame you did not post any fault codes from the ABS module.
    Daniel.
    Dec 2006
    494
    Sounds to me like your 'longitudinal acceleration sensor' needs replacing. It should cost about 90 - 130 and will take about 1hr to fit.
    05 Audi A4 2.0T Quattro
    Black with a BIG wish list!
    Mar 2008
    30
    I had a similar issue, started intermittently with the ESP light, then ESP stayed on then ABS light came on intermittently (on start up and when moving at times). When I serviced the car, the Vag Com came up as Steering Angle sensor. Apparently it's a sensor in the steering wheel that senses the amount of turn you are making in relation to amount of power being put down. Apparently it either requires replacing or cleaning. I didn't get round to it but during the ice we had recently, the wheels were spinning on ice on the road and all the warnings disappeared. It's like when the wheels slipped it might have reset the ECU and all lights have disappeared.
