Chris NottAH Fabrications
    Mar 2008
    23
    Central locking problem
    hi all, i need some advice/help
    my audi A4 b6 1.9 tdi is giving me these problems
    Central locking is not working.... i can lock my car with the key fob but it will not open any doors with the key fob.
    i open the car using the key via drivers door then start the engine and unlock all other doors from inside.
    also to lock the car from the outside i have to press the unlocking button on the key fob?? and the locking button does nothing.
    i have put a new battery in the key fob no luck.
    Garfie's Avatar
    Jul 2009
    Ipswich, Suffolk
    179
    Have you checked the fuse for the central locking?
    Mar 2008
    23
    Quote Originally Posted by Garfie View Post
    Where can i find this ...had a look at the ones on the driver side panel and i can not find 1 for the central locking
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    Fuse cover is on the side of the dash as you open the driver's door..
    Check fuses 24 , 23,25 .I had the same problem
