AH FabricationsJMB Retrofits
Results 1 to 7 of 7
    abmunro's Avatar
    May 2004
    Durham UK
    76
    Leaking soft top
    I have returned to Audi ownership after 4 years.
    I had a 2001 S4 that had all been done by ABT. 4 year ago I traded that in and bought 2001 BMW M3 Convertible.
    Yesterday I traded M3 in for a 2004 Audi A4 2.5 TDi Sport Cabriolet.
    I woke up this morning to find water on th passenger seat.
    It was really stormy.
    Has anyone else had problems?
    What is repair is it usually seal failure or poor aligment etc.
    Tony
    2001 ( 51 plate ) BMW M3 convertible, 19" M3 EVO alloys.
    1992 Nissan Pulsar GTiR 345 Bhp.
    1991 Mazda RX7 Turbo 11 Convertible
    All above cars have been replaced by below
    2004 Audi A4 2.5 TDi Sport Convertible
    1991 Lotus Elan SE
    2004 Focus Cmax Zetec TDi
    Apr 2009
    Shirley, Solihull
    542
    Hi and welcome to the site
    Get yourself down to halfords and get an autoglym soft top kit, contains a bottle of cleaner, a bottle of waterproofer and a sponge. Follow the instructions and give the roof a clean then give a good coating of the waterproofer and that should do the job! The roofs do 'seep' through if they are not treated regularly (every 6 months or so) and you should get 2 treatments from the kit for 20 quid Worked on mine though mine was on the drivers side. Other thing to do is clean and treat all of the rubber seals.
    Hope that helps
    Mark
    ps.... you've missed the 'n' in your sig !!!
    Available soon in the For Sale Section.....
    RS4 Pedals - Drivers side mirror mounting/wiring
    B6 Cab Front Grills - Drivers side B6 Cab Headlamp
    Moro Blue Mirror Caps - Full set of Cab Windscreen Surrounds
    Symphony 6 disc Head - Unit Full set of B6 Cab Manuals inc Leather Wallet
    N/S B6 Rear Lamp - RS6 Auto Brake Pedal
    PM for more details.......
    abmunro's Avatar
    May 2004
    Durham UK
    76
    Thanks will try it out...
    1991 Lotus Elan SE
    pjmspeedy's Avatar
    Dude, what's mine say ?
    Apr 2008
    North West
    1,057
    Or if your feeling flush buy the Renovo Kit. In fact I did mine with this over the weekend ready for the winter. I personally think it's better then the Auto Glym kit but then it is double the cost!
    http://www.elkparts.com/car-care/ext...t-c.p2575.html
    Check that your windows are shutting all the way up once you shut the doors.
    Audi A4 1.8T Sport Cabriolet-Full black leather(Electric & heated),RNS-E,BOSE, OEM Bluetooth,RS4 Mirrors,RS4 FBMFSW,RS4 Pedals,RS4 RARB,Cruise Control,B7 Rear Lights,Ally Inlays,18" RS6 Alloys,HID's/Auto lights with dimming rear view mirror,Coming home lights,Ambient light pack & Rear parking sensors.
    For all your VAG OEM PARTS send me a PM or e-mail me at vagoemparts@ymail.com
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    get a hose pipe oout and find where its leeking from first, spray upwards on the windows, not getting the roof wet, iliminate one thing at a time, its more than likely the window seals. if nothing from there, then carry on round to the front seal above windscreen, again rule it out, still nothing then soak the roof.
    cant sea it seeping in the roof, must be a seal in my opinion.
    the comments from the two guys above are spot on, but id find the spot first.
    the cleaning/ sealing kits they mention are ideal, cant comment on the one speedy mentioned as ive not used it, i use the autoglym one and it does a great job.
    LOTS DONE, LOTS SPENT !!!!
    abmunro's Avatar
    May 2004
    Durham UK
    76
    I used Autoglym.
    Will see what happens
    Tony
    1991 Lotus Elan SE
    Mar 2009
    53
    I had the exact same problem in the exact same place last winter. Fine, treat the roof as a matter of course, but most importantly clean the seals.
    Especially clean the metal where the front seal interfaces, this can get very grubby and take a good scrubbing to get clean. Basically, anywhere there is a build up of dirt, the rubber will not form a perfect seal and water may get in.
    Also prime culprits are blocked drain holes, these are small holes in the rubber 'cups' that catch the roof bars at the tops of the screen pillars, a straightened out coat hanger with a bit of tape wrapped around the end (so it isn't sharp) can be used to rod these, they go right down the pillar.
    If you are feeling flush, you can also buy a bottle of Krytox from VW/Audi to lubricate and refresh the seals.
