Volks AutosMonster Motorsport
    Oct 2009
    Max Boost Safe Boost Pressure Rating?????
    hello every1 im new, i hope your all well!!
    i have bought a boost controler for my audi a4 1.9 tdi 130bhp 6 speed avant and im needing to know my Max Safe Boost Pressure Rating
    can any body answer this or let me know how or where id find my answer
    many thanks in advance Reillly
    ill look forward to talkin to you all
    Marc1's Avatar
    Feb 2008
    721
    Be careful with that, you need to alter the fueling as well as the boost. You don't want to go over 1.4bar, but bear in mind that the higher the boost the faster the thrust bearing will wear. Just get a remap to alter the boost and fueling more safely and have better results, there's a lot of forum deals around.
    For Sale
    B6 S Line Saloon rear bumper,B6 A4 Upper Grille,B6 1.9TDI catback exhaust,B6/B7 Full Piano black inlays,B6/B7 RNS E/GPS Sharkfin,B6/B7 Side airbags,B7 2.0TDI Intercooler and MAP sensor
    Sep 2003
    Bournemouth
    312
    I don't think it will work mate, as soon as the ecu sees to much boost it will go into limp mode (shut turbo down). On old skool turbo charged engines which used a map sensor connected via a rubber pipe you could use a bleed off valve but risky if not setup 100%.
    FOR SALE... 2007 Rns-e (sds), 2009 OEM bluetooth module, Flat bottom TTRS MFSW, steering wheel control module and slipring. All in Classifieds, Pm me if interested.
    RS6 Avant, Milltek non res, Forge, ITG, Bilstein, Hotchkis.
    Marc1's Avatar
    Feb 2008
    721
    Good point there, I forgot to mention the limit would also need raising, doh!
    Don't do it, get a remap!
    For Sale
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Oooh scary! Rather you than me!
