Volks AutosChris Nott
    Oct 2009
    Help! All windows not working
    Hey
    My GFs dad A4 Soft top 2006, b6? i think it is, German stuff is new to me unfortunately so I cant really help him.
    Basically all the windows dont work at all, no matter what you do, so the drivers side window is stuck part of the way down, which obvioulsy isnt good.
    Now we have had a diagnostic machine on it and these fault codes that it brought up
    01331 - Door Control Module, Drivers side
    00470 - Combination Comfort Databus in single wire
    Any help would be greatly appreciated.
    Drew
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Hi is the any water in the passengers side footwell
    it may be that the comfort control module is wet
    its under the carpet in front of the seat
    just a thought as it does happen .
    Sep 2003
    Bournemouth
    312
    I had a similar fault on my Avant, the 01331 code is the control module in the drivers door and is part of the motor assembly. Luckily mine was just a poor/corroded connection on the multiplug going into this but you need to check the wiring going from the car through the rubber bellows and into the door itself aswell.
    FOR SALE... 2007 Rns-e (sds), 2009 OEM bluetooth module, Flat bottom TTRS MFSW, steering wheel control module and slipring. All in Classifieds, Pm me if interested.
    RS6 Avant, Milltek non res, Forge, ITG, Bilstein, Hotchkis.
    Oct 2009
    ok thanks guys, il try and check tonight when hes home!
    thanks for the help, il report back my findings
