Chris NottMonster Motorsport
    Oct 2009
    Error codes p3105 and p19561
    Hi all i have an a4 turbo diesel 2004 and i ran it low on diesel last week and now when driving sometime s it happens its like the engine shuts down or loses power kinda shudder s revs drop if i accelarate hard a puff of black smoke out the exhaust and away it goes perfect sometimes this can happen every min for a bit other times like on a motorway it never happens so first i think i did was added injector cleaner to the diesel still no good so took to local garage today changed fuel filter and checked for errors it gave me p3105 intermittent and p 19561
    The code 19561 - Valve for Intake Manifold Flap (N239): Open or Short to Ground
    The code P3105 - Intermittent
    so any suggestions what to do next all help appreciated
    technics100's Avatar
    Feb 2004
    Co Antrim
    772
    Looking at the Ross-Tech Wiki, the fault code is
    19561/P3105/012549 - Valve for Intake Manifold Flap (N239): Open or Short to Ground
    Possible Symptoms
    * Engines shakes at shutdown
    Possible Causes
    * Wiring Open Circuit or Short to Ground
    * Valve for Intake Manifold Flap (N239) faulty
    Possible Solutions
    * Check Wiring for Open Circuit or Short to Ground
    * Check Valve for Intake Manifold Flap (N239) > Output Test
    So I would check the to the intake manifold flat and also do an output test using vag-com.. here is a link with more info from TDIclub
    http://forums.tdiclub.com/showthread.php?t=28793
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
