kash - if you can get to something like the Chip'N'Spin rolling road days, then it is WELL worth the while to get a proper rolling road power run, then do the remap and then a post-map run too....
You would be stunned at the number of guys that were being sent out with "yes, the remap would make it faster, but there's some other stuff to sort out first before outting any additional strain on the car"
edit: and no - they're jsut a chipping place - they weren't fishign for extra work at all...
there was even one Mk5 Golf GTI (about a year old) that returned virtually no extra power at all due to some faulty turbo sensors... a remap would have given him a tiny bit more torque itn eh mid-range, making it feel quicker, but aside from that it would have jsut over-fueled and probably ruined his catalytic converter...
for £250, it's the same kinda price to a budget box and you get the re-assurance of knowing the car is actually performing at/close to the expected levels.... at very least pop around to your local rolling road afterwards (preferably before and after) for a couple of dyno runs to check that it's having the desired impact without any unpleasant side effects.
RE the fwd TDI's in particular.... rememeber - they DON'T make the engine more revvy, you'll still be changing up at the same points, they just give you more torque through the mid-range and high-ish end of the rev-range...
net result more strain on the clutch, so be careful if you slip it out gradually to make smooth take-offs as you'll have a LOT more torque at the lower end to do damage with and also once that torque is down onto the wheels you're a lot more likely to spin up... especially in the wet!!
