EM TuningChris Nott
    Sep 2009
    Misfire - Not coils or plugs
    Hi,
    I'm new here, but have been looking through the forum for nearly a week now.
    I bought a 2003, 2.0 FSi last Sunday and knew it was misfiring but knocked the price down a bit to account for this and the risk I was taking in buying it.
    Anyway so far I have fitted four new coil packs and plugs, and the coil packs made a hell of a difference. However it is still misfiring occasionaly when driving along.
    I got Vagcom working and there were a lot of fault codes left over showing such and such cylinder not firing, so I cleared these and then went for a drive, re-checked the fault codes and only one was logged. Unfortunately I've cleared it now and forgot the actual code, but it was described as something like 'unexplained misfire, undetermined cylinder'.
    Does anybody have any ideas?
    TIA
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Hi
    a lot of VAG cars use ignition amplifiers ,
    these will cause missfires and are often overlooked
    but in all honesty im not sure if the FSi uses them
    there generally mounted in/on the air box to keep them cool
    worth a mention
    Paul
