Monster MotorsportEM Tuning
Results 1 to 14 of 14
    M4KTT's Avatar
    Feb 2003
    liverpool.Northwest UK
    95
    Xenons and radio interference
    Has anyone ever had a problem with poor radio reception / signal when they switch their xenons on?
    I've had the retrofit kit in for probably 24months, and when on start up(headlights) the radio reception is poor...it improves once the lamps have warmed up but still inst perfect until i switch them off...
    hence why i listen to CDs alot... but now that the early mornings are dark I want to fix this fault...
    I hear that earthing the ballasts solves the problem, but i thought I'd do a bit of research first on here...hopefully someone can shed a bit more light onto it before i start dismantling my car...so much for my mega tidy install hiding the ballast from sight!
    2002 1.8t se, leather, concert, gmbh kit, 19" RS6, 210bhp Tophtechnik remap
    26,776
    When I fitted oem bixenon adaptives I had a similar issue, I resolved this by way of coding the car correctly & also upgrading the module 09 J519 to be able to handle the upgrade, once coded & changed over the noise went away immediately.
    Yours would be best via an earth cable at 1st, test it temp by way of wire round units & touch on the chassis or earth point, be careful cause startup power can give a hell of a whack.
    Why not source a set of oem's & fit?
    Garfie's Avatar
    Jul 2009
    Ipswich, Suffolk
    179
    I'd also be interested in a fix for this. My radio reception in my Avant is pretty poor in the first place anyway, but when I turn on the HIDs its nearly non existant.
    26,776
    Are yours oem or aftermarket
    Garfie's Avatar
    Jul 2009
    Ipswich, Suffolk
    179
    Mine are aftermarket (big ballasts). They were fine in my Mk4 Golf, didn't cause any interference in that.
    26,776
    Could try shielding the ballasts from any surrounding wiring so it cant be picked up by anything, maybe its giving of an inductive field onto wires close to it that is ultimately affecting the cars radio system.
    Garfie's Avatar
    Jul 2009
    Ipswich, Suffolk
    179
    It is possible that could help but no idea how to go about it.
    I have been considering upgrading them to the newer slimline ballasts if people can report they don't get the interference with those.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,730
    Quote Originally Posted by M4KTT View Post
    That exactly the problem I have too. I have the slimline ballast's so I dont think that idea would work sadly.
    iyrix's Avatar
    Mar 2010
    427
    I've now got this problem.. lol
    Looks very normal with aftermarket xenons. I have an idea im going to work on, changing my backing plate from perspex to either a slim piece of wood or metal. I think the metal is more likely to conduct though?
    Has anyone had a fix?
    Graham
    Audi A4 TDi 130 Sport
    chrisash32's Avatar
    Manchester
    575
    just for the record, i have the same problem too....
    iyrix's Avatar
    Mar 2010
    427
    im going to work on this over the weekend. WIll let you know how i get on...
    It will be really annoying if its not fixed during the winter!
    simon.m's Avatar
    Oct 2009
    2,746
    not sure if this is of any help but i no years ago you used to get a wine/buzzing on the stereo and you could just buy a reducer
    from any good car shop to stop it im not 100% sure but i think you just cut into the live wier and but it inline with it job done.
    so id think you can just do the same with the lights. try maplin or some where like halfords for the part just a thought guys.
    Apr 2010
    11
    Its called RFI or radio frequency interference. Earthing will definately help. As will sheilding the connections with any insulator.
    iyrix's Avatar
    Mar 2010
    427
    Does anyone know if the ballast's get hot? and are these the likely cause of the interference?
