Volks AutosAH Fabrications
Results 1 to 11 of 11
    Oct 2008
    Newcastle upon Tyne, United Kingdom
    85
    A4 Avant Number plate lights
    Hi,
    I am in the process of changing the number plate lights on my avant due to the screws being totaly rusted. The passenger side bulb was not working hence why i started this job.
    Problem is the blown bulb did not show up on the DIS. I removed the faulty light to find the holder totaly corroded and the bulb was well blown. I have cleaned up the terminals and tried the known working bulb from the other light but no joy. Funny thing is when I took the bulb out the other light it then threw up the bulb blown messgae on the DIS.
    I'm of down to maplin later to get a cheap circuit tester to check there is power to the light. Just all seems a bit odd
    Any ideas?
    52 A4 Avant 1.8T Sport Quattro
    Metallic Atlas Grey
    Leather/Alcantara, Xenon, F&R PDC, Ambient lighting, Storage pack, Interior lighting pack
    Oct 2008
    85
    Panic over....getting power to both lights so will have to fiddle with the new bulb holders to ensure connection. One thing is for sure, Audi didnt design the number plate light holders very well. The screws are a very soft metal and are awkward to get at straight with a screwdriver. Im guessing given the life of the bulbs the holders probably need to be changed with every bulb change due to stuck screws. hey ho!
    Next job. Change the rear disks...
    Metallic Atlas Grey
    Aug 2009
    833
    what size bulbs are they as i wish to change mine for leds.
    pjmspeedy's Avatar
    Dude, what's mine say ?
    Apr 2008
    North West
    1,057
    I went to put LED's in mine yesterday....however it was a ***** to get them undone and I could see through the lense that they looked quite corroded.
    Anyway undone one after about 5 mins and found that because of the screw was rusted into place that it snapped the lug that it sits into on the other side! So it won't now stay in place so I had to order myself some new ones for Monday to sort the problem.
    Audi A4 1.8T Sport Cabriolet-Full black leather(Electric & heated),RNS-E,BOSE, OEM Bluetooth,RS4 Mirrors,RS4 FBMFSW,RS4 Pedals,RS4 RARB,Cruise Control,B7 Rear Lights,Ally Inlays,18" RS6 Alloys,HID's/Auto lights with dimming rear view mirror,Coming home lights,Ambient light pack & Rear parking sensors.
    For all your VAG OEM PARTS send me a PM or e-mail me at vagoemparts@ymail.com
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    speedy, wont led's throw up a bulb out on the dis
    LOTS DONE, LOTS SPENT !!!!
    Oct 2008
    85
    I can confirm the LED's do cause the DIS to show the bulb out message. As this is what i fitted.Will look at getting some resistors for mine or just swap back to normal bulbs. Mind you the LEDs do look much cleaner and more modern.
    During the course of trying to get the old holders out I noticed the black bar that houses them was very corroded so might try and get that off for a respray next week when I am off and also looking at the rear wiper motor that has never worked
    Metallic Atlas Grey
    V6 Quatt's Avatar
    Feb 2008
    748
    You can now buy LED numberplate lights with built in resistor so no wiring needed.
    I purchased some from Alltronix. But the owner of the website is away on business until 28th eptember well worth a buy.
    See: http://www.alltronix.co.uk
    Quote Originally Posted by b00zehound View Post
    Torque the Torque
    Aug 2009
    833
    i have some resister for em anyway, perks of being a microelectronics engineer :D just wondering what bulb type it is!!
    Oct 2007
    69
    Quote Originally Posted by V6 Quatt View Post
    I am also after a set of these but that site is down does anyone else know anys sites that sells these with the built in resistor??
    3.0 V6 Quattro Sport.
    Aug 2009
    833
    Quote Originally Posted by -chris- View Post
    seeing as the guy says hes away till the 28th im holding out that they will be back next week sometimes.
    Sep 2009
