Sky InsuranceChris Nott
Results 1 to 16 of 16
    boya's Avatar
    Aug 2009
    consett county durham
    394
    What bulb type in a B6?
    it has halogen lights at the min but am considering upgrading to hid's but what type are my current bulbs? h7's??
    Apr 2007
    Wirral
    196
    h7 for dipped and main beam for halogen headlights.
    boya's Avatar
    Aug 2009
    394
    so am i right in thinking that the bulbs for dipped and main beam are both h7's but separate? cheers
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    correct both H7 .
    s-line stu's Avatar
    West Midlands
    183
    As an alternative why not try uprated bulbs like Osram Night Breaker or Phillips Ex-treme as I gather this will give much better light than standard for a fraction of the cost at around 15 a pair.
    May 2007
    Chorley, Lancs
    781
    I changed my Main Beam to H7 Phillips Ex-treme - miles better !!!
    Monza Silver A4 2.0TDi S-Line Avant Quattro (170) - Heated Alcantara Leather, Sat Nav, Bluetooth, Folding Door Miirrors, Electric Tailgate, Privacy Glass, etc
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Quote Originally Posted by s-line stu View Post
    I used the osram bulbs but they only lasted around 12 months and for the price i personally wasnt happy and they were not much better either to be honest .
    Kolyan's Avatar
    Newbiest Noob
    Sep 2009
    Florida
    low light intermittent
    Hello fellow enthusiasts.
    I've got "Osram Xenarc" in "low light" portion.
    Recently I started receiving that bulb with red cross and some freaky looking German command display in that little window on dashboard. Its really intimidating sometime, isn't?
    I just fixed "break lights" signal for a bulb at passenger's side a few month ago. Clever mounting structure!!
    So the "low lights" kinda intermittent on and off but last 2 days was off all the time. So my lovely wife got written warning for that last night, and here I am: googled some instruction, got replacement ($130 for the bulb, made in DE, Denmark I'd guess) and began sacral dancing in front of the piece of precious machinery.
    Pulled out the headlight, unhooked all these wire latches off, pulled out the victim, replaced it, turned lights on - Jesus with Rusty Shmeisser! It works!
    Packed everything back, start the car, changed parking - still works.
    Later tonight my wife decided to run away for some shopping and ... yes, my good fellas, the s... comes back again. She was driving back home on hi-beams (). If any of you got offended - my apologies.
    Does it sounds recognizable to any of you so far?
    I did not rushed down to fuse box by 2 reasons: first - I don't even know where it is; and second, ones fuse blows - then light is gone permanently, not back-and-forth, right?
    I've had almost the same intermittency with my "break light". It was about the same on and off for sometime. So thats why I ordered damn bulb right away.
    SOS! SOS! SOS!
    Thank you all.
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Sorry Kolyan, I've tried to make sense of your post I really have, but I just can't seem to get my head round it.
    Can you please explain the problem again? Are you saying your dipped beams (the projector) keep failing? Or is the problem with the city lights (side lights)?
    Kolyan's Avatar
    Newbiest Noob
    Sep 2009
    Florida
    Well, I was tried to get some humor into the situation. Sorry.
    What happened is after replacement it still not working. So I have to go down the food chain I'd guess. Like relays, fuses, wires, light turning knob.
    So my Q: does anyone ever experienced something like this and what did they found?
    The lights that I am talking about are "low lights", may be driving lights. Thats what guy at Autozone told me. Yes, they are kinda with a lens and when car starts they move a bit. What is the "city lights" then?
    Thanks to all
    boya's Avatar
    Aug 2009
    394
    side lights (city lights) - first setting on your light knob
    driving lights (dipped beams) - second setting on your light knob
    main beams (bright as fook) - second setting on your light knob with indicator stalk bushed forward.
    Sep 2009
    London
    similr low beam prblem
    I have a similar problem in that I've changed bulbs and checked fuses but the problem of no low beams on both sides remain. Has anyone come across this before and do you knw how to resolve this? I have a B6 A4 2002. Cheers
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Quote Originally Posted by Kolyan View Post
    Thanks to all
    It sounds like you've got xenons, the problem could lie with the ballasts (the metal battery pack looking thing which sits underneath the headlight).
    Jan 2006
    UK, Blackpool
    100
    Don't know about anybody else, b ut I've got a 2004 3.0Q B6, and I've got H7's for dipped and H9's for main beam! They've got different plugs and everything for the main (full) beam.
    I know this as I've just taken my headlights out to check my bulbs as I had a misplaced bulb on the drivers side.
    I don't have xenons and I don't think I have the HID conversion.
    Andy
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Never seen anything but H7 in the headlamps for dip and main ,
    and H11 in the fogs a H9 is the same bulb without the blackend as a H11.
    Kolyan's Avatar
    Newbiest Noob
    Sep 2009
    Florida
    Xenarc madness
    Fellow Enthusiasts!
    Thank you for your kind and swift replies.
    The think is still intermittent and I'm afraid required some more investment.
    I have some sources to check-out here:
    http://www.yourhotcar.com/product/li.../HID_Ballasts/
    http://www.gasgoo.com/auto-parts-tra...D-Ballast.html
    http://cnlight.manufacturer.globalso...ID-ballast.htm
    supplied by some fella AUDIst.
    I'll sure post an updates as soon as I'll get some dough for this.
    Thanks to all and happy driving!
    Wherever you go - therever you are. (The Greatest Awesomeness And Truly Philosophical American Classic Of All Time)
