Chris NottBadger5
Results 1 to 7 of 7
    Sep 2009
    Preston, Lancashire
    50
    18" S-line wheels.
    Hi all, i'm wondering if the A3 s-line (rs6) wheels will fit my car, I've recently bought a 51 plate A4 1.8T and am looking at upgrading from the standard 16" 5 spokes.
    I've just bought some genuine s-line alloys from a 55 plate A3, as I thought the alloys where the same across the range.I know the pcd is the same 5x112 but the thing thats worrying me is the offset as I think its ET54. Would i need spacers or is that offset ok. Tyre size is 225/40 18
    Thanks in advance
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    I think you might need spacers. I think the A4 is about ET45 or so.
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    A4 is ET54, S4 is ET45 and I think anything up to ET40-ET35 should work fine if the car's not been dropped too much... I think some people are runnign ET30, but then you're getting into stretchign the tyres so they curve at the edges and don't rub....
    LostBok/BahnStormer77
    Sep 2009
    Preston, Lancashire
    50
    Hi thanks for your replies, so they should fit no problem then if the offset is 54. I think the wheels are 7.5x18.
    The car hasn't been dropped and has the standard SE suspension - comfy but handles a but like a boat in imo.
    technics100's Avatar
    Feb 2004
    Co Antrim
    773
    I would test fit a front and a back and feel around the suspension arms and see if they clear OK. the 54mm might look to sit too far into the arch, 10mm spacers might just help the look a bit.
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    Sep 2009
    Preston, Lancashire
    50
    Yeah i'll probably try that 1st, but as you say they might sit in too far. If I get 10mm spacers will I need to get longer bolts? Might be better just to sell these on and get the proper size for my car. Am I correct in saying A4 alloys are 8x18 ET43
    Feb 2004
    Co Antrim
    773
    Yeah, you will need longer bolts, I'm running 18" RS6 reps and they are 8 x 18 with a Et45, they are quite close to the suspension arms, I can just about get my fingers around the back on the wheels
