Driving me mad!!
QuottroA4
NULL
Can I throw this one out to the forum as I am going slowly mad trying to figure out this problem!! :keule:
I have a droning noise come from what I think is the exhaust which only happens under load between 1900 and 2400rpm. It is most noticable on the daul carriagway or motorway when accelerating in 5th or 6th gear.
I also still have the old problem of my exhaust resernating at idle (esp when cold) which has seemed to remain constent and not go any worse.
I think both the issues are linked as both involve the exhaust system. I have narrowed the possible causes down to:-
- Stiff flexi joint on cat unit
- Stuffed hydraulic engine mount
- Worn DMF (£££££££ :sadlike:)
Has anyone had experience of anything like this? I'm erring towards option 2 myself but cant be sure!!
Thank you in advance
Rich :)
Is the exhaust stock item , if so how old is it , do you feel there is a lose in power..
Stock on a 52 plate = 117k
Had local indy garage look at it and they said they could find anything wrong, even took the cat of to have a look at it..
I had a similar issue on one of my 100k + mileage diesel A4's, I think some passats suffer from similar symptoms. Apparently its because the flexi-joints in the exhaust harden up over time and the exhaust note changes.. I never did much about it. You could try a new flexi joint and see.
Theres an exhaust pace just across from whereI work, they said th coud chap the old one out and weld a new ne in situ from 80 quid. Might give them a shout to see if they can do it. If it still persists then it must be an engine mount as the car does move when I 'pep' the acelerator at tick over..
Hi QuattroA4, Did you manage to get to the bottom of your vibrating exhaust i have the same problem ..........
Many Thanks
John.
