Volks AutosSky Insurance
    Sep 2009
    A4 Avant B6 Bonnet Release
    Ok i need to get into the bonnet it has been a couple of weeks since i checked the oil.
    I pull the Release leaver in the drivers compartment, this has no effect on the grill pull leaver, the bonnet dose not pop onto the safety catch. I feel no tension in the cable.
    Can i remove the font upper grill easy (without causing too much damage to the grille) Will this give me access to get the bonnet open.
    Any help is much appreciated.
    Simon
    Garfie's Avatar
    Jul 2009
    Ipswich, Suffolk
    179
    I had this once before on my Golf and found if I got someone to put downward pressure on the bonnet over the latch and pull the release lever at the same time it would open.
    However, as you say there doesnt feel like there is any tension in the cable you may have unluckily snapped the cable
    If the above doesnt work I'd look at the footwell end of the cable first and see if its still attached to the release lever.
    Jul 2008
    334
    I agree with garfie, the same thing happened on my b6, i pushed down on the bonnet continuously, got my old man to pull the lever and it opened. my mechanic then greased it up, and it seems to be working well now...
    Audi A4 1.8T SE
    FOR SALE:
    Audi A4 B6 Weitec 45mm Lowering Springs (FWD Petrol) - Offers
    Audi A4 B6 Weitec Ultra GT Dampers - Offers
    Sep 2009
    Got it open with the pull the leaver and push the bonnet down trick.
    But my old man snapped the release leaver......
    All greased up and working now, i just need a new leaver.
    Thanks for the advice
