EM TuningVolks Autos
Results 1 to 20 of 20
    May 2007
    Chorley, Lancs
    781
    RNS-e Directions on DIS
    Hi...
    I have an RNS-e installed in my B6, as well as the full red DIS. (i.e. I can select current MPG, miles to go on current fuel in the tank, time I have been driving, etc, etc, via the right hand stalk on steering column). When I get a fault though the fault indication is shown on top third of the DIS in colour.
    So, can my car be VAGCOM'd to show the driving directions on the DIS or not ?
    Monza Silver A4 2.0TDi S-Line Avant Quattro (170) - Heated Alcantara Leather, Sat Nav, Bluetooth, Folding Door Miirrors, Electric Tailgate, Privacy Glass, etc
    jwhat's Avatar
    Oct 2006
    Ireland
    524
    I think you can get it on the dis but there is a glitch that after you plug in the destination you have to turn the rnse off and back on or something.
    Niknak's Avatar
    Oct 2006
    manchester
    864
    John
    I have RNS-E and as jwhat says to get the directions on the the dis you have to load in your destination into the unit then turn it off then back on again and the directions then are shown on the DIS.
    Ian
    May 2007
    Chorley, Lancs
    781
    Thanks Ian... just tried that but it does not work....will ask Gareth on monday...
    27,073
    Maybe coding isnt correct, you got vagcom to check.
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Sounds like the "Instruments" are not coded correctly.
    For module 17-Instruments
    Channel Adaption 62 - Should have +1 (Radio info) and +4 (Nav Info)
    So set at least a minimum value of 5.
    (Other options are +2 for Telephone , +8 for Telematics - adjust accordingly)
    As you have OEM Bluetooth also add another +2, so final value will be 6.
    With regard to the "RED-DIS Bug".......
    With the RNS-E already on at ignition time then no NAV or Compass information is shown on the DIS. Simply Turn the RNS-E off (Screen goes blank) and back on again and the NAV or Compass information will be displayed on the DIS, other DIS information can be cycled through with the respective DIS stalk select button.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    Apr 2009
    Shirley, Solihull
    542
    As Niknak says, once its coded correctly its a case of turning the unit off for a second then back on again and hey presto all info will be displayed in the DIS.... for info though you don't need to have a destination entered into the nav, in this mode it will show your direction and the name of the road you are on...pretty cool eh!!
    Available soon in the For Sale Section.....
    RS4 Pedals - Drivers side mirror mounting/wiring
    B6 Cab Front Grills - Drivers side B6 Cab Headlamp
    Moro Blue Mirror Caps - Full set of Cab Windscreen Surrounds
    Symphony 6 disc Head - Unit Full set of B6 Cab Manuals inc Leather Wallet
    N/S B6 Rear Lamp - RS6 Auto Brake Pedal
    PM for more details.......
    May 2007
    Chorley, Lancs
    781
    Manyt thanks to those who have provided feedback on this....I will get this "sorted" next monday when I have my MFSW fitted.
    Niknak's Avatar
    Oct 2006
    manchester
    864
    so whats next on the shopping list mate?
    May 2007
    Chorley, Lancs
    781
    Hmmm, the "last" thing I am tempted with is getting the 1.8T rear exausts on my 2.5TDi which has the pointy down diesel exhausts..and maybe that Phatnoise system if I can get a good deal on it...
    Main priority for me is keeping the car in A1 condition...so I may get the entire front bumper/valance resprayed probably next spring
    Niknak's Avatar
    Oct 2006
    manchester
    864
    Quote Originally Posted by JohnboyC View Post
    Same here, my 'new' valance spraying also the rest of the car lol
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    if Gareth (HazzyDayz) or his brother fitted it, I'm sure they would have vagcom'd it... once that's done, the bug on the red DIS is that you have to power the RNS-E off (hold volume in until the screen goes black) and back on EVERY TIME you turn the ignition off.... once that's been doen you can use the full DIS button (or the service interval button) to change it back to trip info, etc.
    you DON'T have program the route in before you do this - but it will only give you your compass bearing until then....
    LostBok/BahnStormer77
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    losty,
    you dont have to go that far buddy, just end route destination and then re-press start destination, pops straight back on again, alot quicker than restarting the rns-e maybe.
    LOTS DONE, LOTS SPENT !!!!
    Sep 2003
    Bournemouth
    312
    Any excuse to show off that lovely steering wheel losty
    FOR SALE... 2007 Rns-e (sds), 2009 OEM bluetooth module, Flat bottom TTRS MFSW, steering wheel control module and slipring. All in Classifieds, Pm me if interested.
    RS6 Avant, Milltek non res, Forge, ITG, Bilstein, Hotchkis.
    Apr 2009
    Shirley, Solihull
    542
    So then, just for fun, what track is playing on Lostboks RNS-E ???
    I FEEL F
    My guess is Chaka Khan - I Feel For You (written by Prince by the way!)
    1wheelonly's Avatar
    cabriolet
    Oct 2007
    The Lounge
    2,062
    i feel free - cream
    BahnStormer
    Feb 2009
    Surrey
    2,582
    ermmm... not sure... I can find out if you really want - pretty sure it's off the missus' "80's Fantastic megamix".... if that helps....
    edit: okay, that's creepy, yes.... Chaka Khan "I feel for you"... and even with the missus driving the radio (no license, so she never gets to drive the car) I think that one would have go the "scroll down" treatment, so volume must have been off! (apols to any Chaka Khan fans out there, but not really my style)...
    ...and thanks 1wheel - I'll try that today!
    Apr 2009
    Shirley, Solihull
    542
    Quote Originally Posted by lostbok View Post
    hehehe...always the doris's fault!!!
    May 2007
    Chorley, Lancs
    781
    Thanks to Hazzydayz meeting with Niknak in Machester - he did the necessary VAGCOM tweak and the RNS-e directions on the DIS now work just great - need to do the frig explained in the earlier posts above....
    27,073
    Told yerrrrrrrrrrrrrrrrrrrr
