Volks AutosAH Fabrications
Page 2 of 2 FirstFirst 12
Results 41 to 48 of 48
Thread: HIDS
  1. #41
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,698
    I had the same problem with my headlight adjustors when I first bought my car, upon further investigation the adjuster links between the light and the electric adjustment motor had come adrift.
  3. #42
    SmoothAssault's Avatar
    Will design for mods
    Dec 2007
    Cambridgeshire
    766
    Oh, so your electric adjuster on the dash wasn't working? My dash adjuster seems fine.
    Only problem is that the zero setting is too high, and so needs to be set to two or three for the beam height to be what I think *should* be zero (acceptable, unloaded height).
    FOR SALE: Eibach Sportline Springs from B5 A4. £50 - PM for details.
  4. #43
    Mar 2008
    Dorset
    13,698
    Quote Originally Posted by SmoothAssault View Post
    Have a look in the manual, from memory the meanings of the settings on the dial isn't as obvious as you would expect!
    If not them just set the dial for 1 (Driver plus no luggage?) and get a garage to adjust the headlights in that position to 'calibrate' the dash adjuster.
  5. #44
    Dec 2007
    Cambridgeshire
    766
    Sounds like a plan. Cheers James
  6. #45
    Garfie's Avatar
    Jul 2009
    Ipswich, Suffolk
    179
    Bear in mind there's 2 adjusters on the top of each headlamp, one for up/down movement and one for left/right.
  7. #46
    silversurfer's Avatar
    Jan 2007
    221
    Has any one changed there Full Beam or Fog light bulbs to match the HIDS.?
  8. #47
    Mar 2008
    Dorset
    13,698
    Quote Originally Posted by silversurfer View Post
    There's loads of threads on this, try HERE for starters.
  9. #48
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,186
    Quote Originally Posted by J7USS View Post
    Hey Razza, them hids you have, are they the tiny Ballasts???
    No, normal size I believe, don't think I've seen "tiny" ballasts?
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
