Badger5Volks Autos
Results 1 to 10 of 10
    Xmay4444's Avatar
    On Point!!
    Nov 2008
    LHR
    255
    Bulb error after HID attempt
    HI all,
    I really need some help/advice.
    I just tried to fit a HID kit and got it working but my front left indicator did not work and I got a bulb out warning on the DIS. So I took it out and replaced it with the original stuff, but the bulb still wont work and the warning is still there.
    How can I reset the DIS so I can start again will disconecting the battery work?
    1.8T quattro S-Line in Akoya Silver, Milltek sports cat & 100mm tipped pipes, black Angel Eyes, 18" RS6's (Vredestein Ultrac Sessanta), Bose Symphony 6CD, Moonroof, Criuse Control, Armrest, Full DIS, 0.5 Leather, F&R PDC, Light Pack, Parrot MKi9200
    Coming soon HID's
    2001 1.8T Sport 0 v Swedish Artic 1
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    I had same problem on my old car. It turned out the HIDS were fine and the reason for the warning was the actual connection to the indicator - I must have caused it when messing around fitting the hids....
    Try putting your hazzards on and give the headlamp a slight tap near the indicator side first, failing that then fiddle with the wires for the indicator and see if that helps!
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Take the indicator bulb out and check the contacts around the round black plastic bulb holder removable part. You may need to just slightly bend the metal contacts of the removable part to make decent contact with the Headlight assembly.
    Had this a couple of times - once embarrassingly during an MOT and the DIS said nothing!
    Replaced the bulb was OK - got home went again came up on the DIS - adjusted the contacts as described above and ended up putting the original bulb back in - all OK now.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    Xmay4444's Avatar
    On Point!!
    Nov 2008
    LHR
    255
    Thanks guys, I will have a good look at it when it comes back from my local dealer as it is in for a serrvce.
    I have also noticed a very high pitched noise from the headlight unit when the lights are swithched on, but it then stopps after about a minute.
    Wny ideas?
    Coming soon HID's
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    If the HIDS are still fitted, its the sound of them powering/warming up
    Woorlord's Avatar
    Dec 2007
    Tiptree, Essex
    948
    HID's need to generate typically 23kV (23,000v) from your car battery's 12v so utilise high frequency inverter technology to do so. You are hearing the transformer windings buzzing at these high frequencies!
    This is normal.
    audimatt's Avatar
    Jun 2007
    38
    Hi, sorry to sort of go off topic..
    I'm looking into getting a HID kit; do i need H7 bulbs for my B6. Thanks
    golf's Avatar
    ***** rent boy
    Jan 2007
    London
    1,553
    Quote Originally Posted by audimatt View Post
    Yes, you need H7. Stick to 4300k - 5000k if you're not a poser. There's a guy in my neighbourhood who has 8000k's fitted in his B6, the amount of glare and colour is ridiculous.
    J7USS's Avatar
    Shuddup Foooool!!
    Oct 2006
    LEICESTER
    3,671
    I have 6K....and to think about it, Im a poser too but that was way before my 6k's!!!
    Xmay4444's Avatar
    On Point!!
    Nov 2008
    LHR
    255
    That whine i was talking about, at first I too thought it was the ballasts, but It's still there after I took the HID kit out.
    I'm now gonna have to drive around without a front indicator till I can have a good look at my headlight unit prpoerly.
    PS my lights are not OEM by the way, (see my avatar).
    Coming soon HID's
