Monster MotorsportChris Nott
    Sep 2007
    23
    2.5 tdi gearbox tdi
    Hi Guys,
    Got a a4 2.5 tdi cabriolet auto. Lights on the dashboard recently came up and car was taken to Audi who stated the gearbox ecu needed to be changed. Cost - 1300.00.
    Does anybody know where this could be done cheaper?
    Apr 2009
    Shirley, Solihull
    542
    Where are you based Baz? Theres a multitronic specialist in Milton Keynes worth a try, you'll have to google them as my main pc is down so can't post you a link, if you're aroun the midlands I can recommend an audi indy who knows all about this problem as he's just had to change one in his own car! Don't bother with the breakers mate, they are programmed to your car and are only available from the factory in Germany via a main dealer at a cost of around 800, then its around 6 hours labour to fit it
    edit: heres the link, they're called indie-tech
    http://www.inde-tech.co.uk/multitronic.html
    Available soon in the For Sale Section.....
    RS4 Pedals - Drivers side mirror mounting/wiring
    B6 Cab Front Grills - Drivers side B6 Cab Headlamp
    Moro Blue Mirror Caps - Full set of Cab Windscreen Surrounds
    Symphony 6 disc Head - Unit Full set of B6 Cab Manuals inc Leather Wallet
    N/S B6 Rear Lamp - RS6 Auto Brake Pedal
    PM for more details.......
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    Quote Originally Posted by markyzs180 View Post
    ... my main pc is down so can't post you a link...
    you need Foxmarks / Xmarks.... allows IE and Foxmarks to cache all your bookmarks online and auto-sync them back to multiple computers (or jsut go online to look them up)... I think there are profiles so it doesn't sync ALL your bookmarks to your work PC
    LostBok/BahnStormer77
    Apr 2009
    Shirley, Solihull
    542
    thanks lostbok, i'll look at that when i'm back up and running
