Volks AutosEM Tuning
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    HEAD SCRATCH (help)
    Hi all just arrived home from a night out ,and just locked the car and the driver's door window went down to half way and the passenger door will not lock all other door's locked but driver's window still open and passenger door lot locking also red light on driver's door on but not flashing..
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,503
    I would hazard a guess it's the passenger door switch, which is part of the lock mechanism. You could remove the door card and WD40 the lock bit, it works for sticky A3's for a while, no reason to think an A4 is much different.
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    Cheers Mark ..I have had the fuse box cover off and the fuse that lock's the driver's door also lock's the passenger door which in turn must aid the central locking.15a fuse number 22 on the fuse panel ...But i still have the problem with the driver's window .If i use the switch on the diver's door i can raise the window up to almost closed if i use the remote to close the window from out side the window will shut then will come down by say a 1/4 ,i think it may need to be hocked up for a scan
    the car locks fine and all other fuses are ok ???????
    Xmay4444's Avatar
    On Point!!
    Nov 2008
    LHR
    255
    Try closing it with the key in the drivers door. Turn and hold the key clockwise, (or is it anti clockwise?), that may help close the window.
    Are all the other windows ok?
    1.8T quattro S-Line in Akoya Silver, Milltek sports cat & 100mm tipped pipes, black Angel Eyes, 18" RS6's (Vredestein Ultrac Sessanta), Bose Symphony 6CD, Moonroof, Criuse Control, Armrest, Full DIS, 0.5 Leather, F&R PDC, Light Pack, Parrot MKi9200
    Coming soon HID's
    2001 1.8T Sport 0 v Swedish Artic 1
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    Xmay all the doors lock now with both key and remote if i use the key to close the window it will close then drop by a 1/4 when i pull the key out...
