EM TuningJMB Retrofits
Results 1 to 19 of 19
    Aug 2009
    7
    Engine replacement due to oil leak
    Hi there, hope someone can help. I have a 2004 Audi A4 1.9TDI
    After having the car serviced (minor service, simple oil and sump plug replacement) by an Audi service center, the car developed a major oil leak. drained completely within 3 miles.
    According to Audi, it has nothing to do with them since it's the sump gasket which broke. And due to the damage now needs a Short Engine and Turbo unit at a cost of 4000.
    If the gasket broke then surely it would not drain that quickly and would have developed a small leak which I may have noticed.
    Is it more likely that the sump plug was not fitted properly and came out, hence drained that quickly since if it was the gasket then there would still be oil in the sump, since the sump gasket is above the sump?
    Of course I just have to take Audi's word that it was the gasket.
    Is there any action I can take against Audi?
    If there is a technician that could answer a few questions for me i'd appreciate it:
    1. Have you ever seen an A4 engine leak oil so profusely from the sump gasket/seal that it completely drains and starves the engine within approx 3 miles?
    2. Where is the sump plug located, is it the side of the sump or bottom?
    3. Where can the oil leak from to completely drain the engine of oil?
    I need to word an email to the service manager explaing why I don't think it was the sump gasket/seal, if anyone could help with that it would be great.
    Thanks,
    Terrence
    technics100's Avatar
    Feb 2004
    Co Antrim
    775
    you need to look at the car and see where the leak came from, surely if the sump gasket was leaking they would of spotted it when changing the oil, the sump would need to be hanging off to drain 4 litres of oil in 3 miles, they would notice that..
    2003 Silver A2 1.4 TDi - 65mpg & 30 a year to tax - ;-)
    2003 Atlas Grey A4 2.0 S-line - gone
    2000 Goodwood Green S6 4.2 V8 - gone
    Aug 2009
    7
    That's what I suspect.
    Unfortunately the car is at the audi dealership at the moment and I wouldn't know how to spot it and I guess they've stripped it all down.
    pjmspeedy's Avatar
    Dude, what's mine say ?
    Apr 2008
    North West
    1,057
    Whatever you do...do not take there word for it! After what you have said I would say that it's there fault 100%. I'm with you that some monkey didn't put the sump plug in properly otherwise if it was the sump gasket they would have spotted it and there's no way that it would drian that quickly.
    Which dealer was this ?
    Audi A4 1.8T Sport Cabriolet-Full black leather(Electric & heated),RNS-E,BOSE, OEM Bluetooth,RS4 Mirrors,RS4 FBMFSW,RS4 Pedals,RS4 RARB,Cruise Control,B7 Rear Lights,Ally Inlays,18" RS6 Alloys,HID's/Auto lights with dimming rear view mirror,Coming home lights,Ambient light pack & Rear parking sensors.
    For all your VAG OEM PARTS send me a PM or e-mail me at vagoemparts@ymail.com
    Aug 2009
    7
    It was Finchley Road Audi (owned by spireautomotive)
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Not a chance in hell would a gasket let go and drain the whole oil just like that.
    You would have needed to have had a hole in the sump for that to happen and an engine light would have come up warning you so.
    I suspect they did not tighten the sump nut which then came out and drained the engine but you would be aware of thins as the engine light would have come on plus you would have left a trail of oil all over the road.
    Someone is bull ****ting you and I would get on to Audi UK straight away plus just turn up to the Audi dealer and ask to be shown the sump and the so called oil leek also take a cheap bottle of oil and fill it up so you can see the so called leek in effect because it will leak instantly by what they are saying.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    You will also find that the sumpplug is not currently there . No chance a gasket failiure can cause 4-5 litres of oil to drain in 3 miles, you could fit the sump with no gasket and it would be better than that. Someone has made a mistake and it's being covered up, simples
    Aug 2009
    7
    The oil light did come on and the car promptly stopped with no power...
    Aug 2009
    7
    Simples I agree, but proving it that's going to be the battle...
    In the process of writing a letter to the Service manager, then based on that reply taking it to the Motor Industry Code of Practice...
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Get on to Audi UK and speak to them, the only way this could happen is if the sump was cracked.
    Ask for there diagnoses in writing and then go down there and ask to see it but I strongly suggest you contact Audi UK.
    Ok just got off the phone to my mate who owns VW enterprise who is a mechanic and he stated.
    1. They do not have a gasket; the sump is sealed by silicon sealant.
    2. Even if the part of the sealant went it could not dump all the oil on the road.
    3. The only way it could was if the sump nut was not done up or you cracked the sump.
    His only words are they are trying to do you over.
    Aug 2009
    7
    Docurley, thanks for contacting your friend.
    I have contacted Audi UK and awaiting there reply.
    I've also contacted the Service Manager at Audi Finchley Road, this is what I wrote:
    I have a few concerns about my vehicle which I'm sure you're aware of via Rafiq.
    1. The car was serviced by Audi Finchley Road.
    2. Approximately a week later there was a catastrophic oil leak causing damage to the engine.
    3. At the side of the road, one of your technicians who was passing by stopped and had a look, he laughed and said someone did not tighten the oil filter or sump plug correctly.
    4. Once at your service centre (Mon 10 Aug), I was told it was the sump plug seal/washer which broke.
    5. Upon further investigation the the cause of the oil leak was said to be the sump gasket/seal (Wed 12 Aug) and not the sump plug seal and your technicians found that I would need a short engine and turbo unit.
    6. Why was I first told it was the sump plug washer?
    7. I don't see how the oil would completely leak out the sump because the gasket is higher than the lowest point. That's the point of the sump.
    8. Also it is my understanding that it is highly unlikely that a leak in the sump gasket/seal would cause the engine to drain completely of oil within the space of a few miles since the sump is effectively the crankcase and as such is only under crankcase breathing pressure which is not much.
    9. I must point out that the oil was flowing out with the engine turned off.
    10. I was also told that had this happened within 20 miles of the service, then Audi would have covered it, but because I did 164 miles it’s not covered.
    11. I find it strange that I was initially told it's the sump plug, then changed to the sump gasket/seal.
    Your thoughts on this matter would be appreciated.
    Let's see what he comes back with...
    Thanks again.
    pjmspeedy's Avatar
    Apr 2008
    North West
    1,057
    Fingers crossed for you buddy
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    it will be very interesting to hear what they have to say.
    RyanJonS4's Avatar
    Drive It Like You Stole It
    Mar 2009
    Oldham
    287
    A similar thing happened to a mate of mine I work with on his astra.
    Its a long story which involves engine mouinting bolts being left out after work by a dealer, his gearbox falling out, and the dealer saying its nowt to do with us and refusing to put it right.
    My mate paid 90 ish for a dvla inspection to be carried out.
    Once he told the dealer he was going down that route, their attitude towards him completely changed and they s**t themselfs the moment he mentioned it.
    My understanding of it is anyone can have this inspection carried out for a flat fee, and the dvla will go over the car with a fine tooth comb and detail anything thats a miss.
    If you log onto direct.gov.uk you should find details about this on there somewhere.
    RyanJon
    Milltek non-resonated cat-back - 15mm MTM spacers - Toyo T1R's all round - RS4 Pedals+foot rest - Blackout model front grilles - Custom black front badge - de-badged boot - R8 oil cap - silver indicator bulbs - Dodo Juice supernatural wax - ECS tuning Porsche cayenne brake kit ready to fit or sell?...
    RyanJonS4's Avatar
    Mar 2009
    Oldham
    287
    Thinking about it now, it may have been a vosa inspection?
    Aug 2009
    Quote Originally Posted by freestuffinnit View Post
    Thanks,
    Terrence
    1. No
    2. The sump drain plug is at the bottom right side.
    3. The ONLY place the oil fill can drain from the sump completely, is via the removed/very loose sump drain plug.
    Think about the dealers excuse, it is unlikely in the extreme. First as already stated, the oil can't escape from the sump below the point where it is leaking from, otherwise only from being pumped out from a pressurized joint/seal/gasket. The sump to block seal has NO gasket, it is assembled from the factory using RTV silicone, the assembled joint thickness is very thin, so the seal won't just fail and exit the joint. Also, there is no pressure on the sump to block joint, so again, that is not a plausible excuse from the dealer. Clearly the sump plug was not tightened properly, and the occurrence of the problem directly after having the oil changed is further evidence the dealer story is without merit. The dealer's excuse cannot withstand rigorous technical scrutiny.
    Aug 2009
    7
    Hi Guys,
    Latest development is that it was the oil pump which failed.
    They admit the sump plug was leaking, as well as the sump seal and they're saying there was still oil in the sump when they took it apart.
    They've dropped the price for repair to 1750.
    I'm still waiting to hear from Audi UK. Unfortunately I need the car back so they're repairing it now, but when I spoke to the motor industry watchdog they're said it's ok to go ahead and have it repaired before they get involved.
    Again thanks for all the help.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    The pump failed!!!!!!!!
    But why would that dump all the oil for one and two seems like they are trying cover there F**k-up if you ask me.
    Sump seal now this.... if there was no oil like they said the first time then yes the pump would fail as it not being lubricated and Yes your oil sump was leaking but not before you brought it in only after they gave you back the car as it would have been spotted before by them as they would have wanted the money to fix it.
    BS again if you ask me.
    Sump was fine and if the pump as gone then it would have be due to no oil but I would lay money on it, it was just the sump nut and they need to shift the blame.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    Yer i agree.
    I'm sure you said up there that there was clearly oil pissing out the bottom of it when you stopped, and that a passing mechanic when he saw it stated that someone hadnt fitted the sump plug. If there was, and no doubt a stream up the road too, then it was not the oil pump that caused the problem.
    The fact the story has changed so many times just makes it all the more unbelievable.
    TD5 Land Rover Defender build
