Volks AutosSky Insurance
    br
    Aug 2009
    A4 airbag sensors
    Hi,
    Where are the side airbag sensors on an A4 avant? I'm assuming they're
    in the pillars somewhere near the seatbelt mounts, or maybe up above the doors where the airbag lives, but I'd appreciate confirmation before I start removing trim...
    Vagcom is saying
    "01222 - Crash Sensor Side Airbag: Passenger Side (G180)
    012 - Electrical Fault in Circuit"
    All clues welcome!
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Just checked my Bentley DVD (so based on LHD references).........
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
    br
    Aug 2009
    Thanks, that's exactly what I need.
    Now to start removing trim and tracing wires...
    Sep 2003
    Bournemouth
    312
    I changed mine a few weeks go quite an easy job with the right tools. Mine had poor connections as the foam that covers it was damp causing corrosion of the wiring and connectors. I covered it in waxol when i put it back in shouldn't happen again.
    FOR SALE... 2007 Rns-e (sds), 2009 OEM bluetooth module, Flat bottom TTRS MFSW, steering wheel control module and slipring. All in Classifieds, Pm me if interested.
    RS6 Avant, Milltek non res, Forge, ITG, Bilstein, Hotchkis.
    Aug 2009
    Campbeltown, Argyll, Scotland
    Hi ! I have just had a repair done on my airbag system ( red airbag light on dash). Turns out it was a snapped wire in the cable under my passenger side seat and the cars ECU was'nt recognising the airbag system. Audi (Glasgow ) fixed it at a cost of 260 ( and that is with a discount ! ) Not cheap !!
    paul20v's Avatar
    Audi fanatic
    May 2009
    S.Wales
    1,108
    Hi
    in the avant i also found them in the rear seat edge back bolster area .
