Well, looked this am no water in car. but I only filled it up a week ago. Not done thousands of miles. So whats happening? I've checked the tank and pipes they're all dry so no leaks that I can see. Anyone had same issues?
Now your problem, well so far it does not sound like the headgasket so I would refill and run the car looking for leeks checking the header tank for a start.
sorry not very mechanically minded, looked at the water tank and pipes that lead off it to radiator. everything seems to be in order. no leaks that I can see or feel.
Same problem on my S4 cab - it was the auxillary rads behind the headlights. THey have a tendancy to leak very badly after a few years. Known issue. Good luck.
