Badger5Volks Autos
Results 1 to 9 of 9
    Jun 2009
    42
    Should my car lock automaticly?
    Not much more to add apart from its a 03 S4, and it doesn't!
    cheers
    Sonnyjim.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Do you mean when driving, like an anti-hijack feature? Or after a period of time when stationary?
    Jun 2009
    42
    no I mean when leaving the car.
    Just heard of the highjacking thing, thought to myself its strange that it locks the doors at 10mph when surely the most likely time to get highjacked is at 0mph. But then I realised that they must remain closed after reaching 10mph for the first time and not unlock when slowing down again! I pressume I'm right?
    Sonnyjim
    Mar 2007
    29
    The short answer is no!
    If you unlock the car and do not open the door or boot it will relock itself.
    The anti hijack if programmed will trigger and lock the car when you hit 10mph/15kmph.
    Jun 2009
    42
    Quote Originally Posted by oneninet View Post
    I'm male so burn all manuals on ownership of anything. Are all audis fitted with anti high jack?
    OK now I feel like a right tit! It does work when I don't open the doors, might RTFM instead of spending time on the net.
    and sorry
    sonnyjim
    Jun 2009
    42
    Reason I asked was that I had a mk2 golf with a after market alarm/CL fitted that would activate after you had left the car, you know open the door to get out sort of thing.
    Sonnyjim
    techboy42's Avatar
    Jul 2009
    Isle Of Man
    7
    Quote Originally Posted by sonnyjim View Post
    and sorry
    sonnyjim
    the anti-hijack thing is normally switched on and off by the dealer or someone with a VAG-COM. It will lock at 10mph and stay locked when you slow down. It's normally the thing you activate along with priority door unlocking so that only the drivers door unlocks with the first press of the unlock button on the remote. A second press unlocks the rest.
    I can't remember off the top of my head if a door will re-lock once you stop to let a passenger out. My gut says the door will re-lock at 10mph as it would defeat the object if it didn't!
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    and once enabled, the normal setting is that it should unlock once you stop and take the key out of the ignition....
    LostBok/BahnStormer77
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    948
    Quote Originally Posted by techboy42 View Post
    .....I can't remember off the top of my head if a door will re-lock once you stop to let a passenger out. My gut says the door will re-lock at 10mph as it would defeat the object if it didn't!
    After auto-locking at ~10mph, the doors unlock again once the car has stopped and the ignition key is removed.
    Passengers may override this by two tugs of the internal door release.
    The driver can also press the unlock button on their door.
    In the event of an accident where the car senses this via various crash sensors, (air bags go off etc.) all doors are unlocked automatically.
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
